Fs: My R32 Skyline With R34 Neo Engine
  • Replies 62
Posted Images
  • 1 month later...
Very smart conversion.I like it.But You should put XR6 turbo on it=400hp
You really have NO idea, do you??? :rolleyes:
Congratulations!! (regarding the baby)
Good Luck with the sale. If i didn't spend so much money on my 33 i would have flown up for a serious inspection. R32 with an RB25 NEO is the ultimate :( !
Guest Miss_Nismo
Sup,
If it is available in 2 weeks, i will offer you that. Hope it still is.
I will still be trying my damndest to sell this car in the meantime unless a deposit is offered.
But, yes if we have been unsuccesuful before you are ready, you are welcome to take it at that price.
We tried fitting the baby capsule, but the rear seat is too small. Hence the baby doesnt get to leave the house until a new ar comes.
Edited by Miss_Nismo
Guest Miss_Nismo
You really have NO idea, do you???  :D
Good Luck with the sale.  If i didn't spend so much money on my 33 i would have flown up for a serious inspection.  R32 with an RB25 NEO is the ultimate  :D !
It really is a serious car, deserving serious inspection. We saw a very similar 32 with same paint (out of a spray can by the look of the quality finish) go for high -teens with the rb20 still in place.
This engine comes on to boost hard and strong (dual stage removed from the solenoid) but is also VERY quiet.
Cheers,
For your sake I hope it goes :D But for mine I hope it stays. I went back to the photos today and didn't notice the engine and interior photos were taken in '02. Do you have any recent ones as I am in WA and wont be able to inspect the vehicle due to a extremely heavy work load.
Does the car have a turbo timer? I dont see any mention of it.
Edited by Tofu
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
