Just wondering how long does it take for a car to leave the shores of Japan and arrive in Melbourne waters?
Does it take a month or 2?
Can I get a friend to pick it up on my behalf if I'm not there to pick it up myself?
Takes just over two weeks from port to port - depending on whether the ship makes any other stops, weather conditions etc.
Once car arrives here, will be inspected by AQIS and Customs. Needs to have the appropriate clearance and inspection documents filled out beforehand. If you have a customs agent they will look after this for you. If not I suggest you search on the forums on the process, has been documented several times before.
Upon clearance you will need a copy of the clearance documents and take it to the docks and they will release the car to you.
took bout 3 weeks for mine to get here.
I thought your broker would work out the clearence stuff and u just had to pick it up or organise someone to pick it up...like a tow truck etc? mine was in a container, delivered to work, so i am not 100% sure about how that works with picking it up at the dock, but i would guess that that would be fine...don't see why it wouldn't be...as long as the person picking it up has the correct documentation, like raz0r said...
My car took about 5 weeks from initial purchase to my driveway, but from what i understand the time is mostly dependent on how soon you can get it on a ship.
As far as getting someone else to pick it up, i know a tow truck driver, and i gave him the necessary documents to clear the car and he went down and picked the car up for me no problems. If you've got the paperwork they dont seem to care who you are. (Possibly not a good thing come to think of it...)
  • 1 month later...
ressurecting an old post....
Once its on a ship, ~2 weeks to melbourne (plus 1 for the mishaps of life)
my problem is getting it onto the ship... How long does import approval usually take to get?
I'm still waiting...
--ebola
Ouch!!!!
It can take from one to about 5-6 months if there is a que for shipping in japan.
lets just hope there isn't.
It had better get here before the new year... its meant to be coming in under the 15 year imports rule (while it still exists...)
wish me luck
--ebola
If you wait for 5-6 months...i think you should ask for your money back lol...that's way too long
Yeah that exactly what I did.
first few months was around xmas etc when it was really busy and they didnt have space for months, the last month they just plain forgot to put it on the ship.
I canceled that car and got something much better.
If you count the skyline I never had then I have owned three skylines... hahah
The journey on the boat takes minimum 14 days from japan to an Australian port. Ships from japan doesn't leave everyday and there is always a long queue of cars waiting for their turn to get on a ship. After the car arrives, it will go through quarrantine and check for soil underneath the car. If soil is detected, the car will be washed thoroughly ( charged in to your account ) and this will delay it even more.
A customs agent will then take over and settle all the paper work including cost of freight, import duty, etc. This alone will take probably a few days.
Compliancing all depends on how modded the car is, if it is stock then no problems it will go through in about 7 working days. If there are problems, it'll take about 2 weeks or so.
Perhaps not quite the right thread, but just in case anyone is interested, import approval FINALLY came in...
I just hope that customes has fixed a few bugs it is having...
yet another skyline about to hit the streets. Well, after shipping, that is
it takes 5 weeks from the day you send for the approval application to received, sometime a bit longer, but no more than 6 weeks. if longer then that is somthing went wrong.
k-line has ship leave yoko, osaka, and nago every foright on friday morning. 2-3 weeks to NSW the melb, the SA after that WA, by the time it arrives in WA it takes 4 weeks in total.
a good custom agent can get your car out of custom and ready to pick up within 2 days. even it needs a clean! but you must provide all the paperwork and cash ready!
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
