  • Replies 46
Guest tkch55
try Maytech automotive if you want quality job done without getting ripped off, their number is 95974111. they've got a wide range of products/brands too, from local brand to most jap brands and custom job. so u can choose what suits ur budget
Edited by tkch55
Hi All,
I am fairly new to skylines and have only had my car for 2 months. Can anybody tell me about good performance guys around in Sydney.
I want to do the following upgrades:
ECU, Intercooler, Dump Pipe, Boost Controller, BOV.
Thanks
If your asking where to buy those parts, I wouldn't be looking at performance shops in Sydney. The interweb is your friend.
If your asking about installation, most of those are very easy and well covered on this forum. Consider doing them yourself if you have the time/tools as its a great way to learn and save some dosh (for more mods of course!).
As always, I'd give Nathan @ Grey Imports ((02) 9519 5150) a shout if your in the inner west area.
Lucien.
  • 2 months later...
spend $900 more on a brand new powerfc, and get about 50% more power.
you serious about this comment - will a power fc increase the car's performance by a lot if you only have an exhaust and airfilter upgrades?
50% is arguable, but yes with a Power FC particularly, you can easily overcome the issues caused by the factory GTS-T engine management when you have the typical exhaust/intercooler/pod type mods and want to run higher boost.
This is just one of the many benefits available when running the Power FC, and at the price they are available for currently, they are excellent value and bang for your buck!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
