  • Replies 47
Sorry "hard tuned" (before I edited it) meant cars with programmable ECUs that tuned to make more power than the stockie ECU. Ie leaner AFRs, more ign advance. Thus they are more succeptable to detonation from a shitty fuel. (being 'harder tuned' than factory if you get what i mean).
They were certainly more succeeptable to detonation after Mik touched them.
Liberty and SAFF now both offer 98RON ethanol enhanced fuel. There is a website that i got from one of Liberty's pamphlets on their 'boost 98' which lists which manufacturers recomend ethanol based fuels. Sadly Nissan say only compatiable with post 2004 model cars, stating fuel componet incompatibilty, or something along those lines. I don't really want to compromise the integrity of the fuel system for a 6-8c a litre saving. Having said that, before i found this out, i ran a full tank of the 'boost98' and found that when going for a cruise through the hills, the ol girl seemed to die a little up the odd hill, actually having to change down a gear to accelerate, not normal. Car in question is R32 gts-t, usual fmic, turbo back exhaust, 14psi and 040.
it was normal, 91 octane lol....don't worry that fuel didn't last very long at all.
it's like running the car on cordial!
Ah, there you go then!!!
Ethanol is crap as a fuel.
Forget the hype, it may not hurt your engine, but it will hurt your pocket!
Ethanol has a calorific value of 1/2 - 2/3 that of petrol. That means, the same volume of ethanol will produce less energy than petrol. SO, it might be cheaper, but your fuel economy will suffer.
Ok, I have done a little bit more research on this fuel.
Speaking to Martin Donnon today, it turns out this fuel CAN be a good thing. If tuned for this "boost 98" every car he's seen has picked up power in comparison to regular 98 octane fuel.
There is a catch however. He showed me some dyno graphs, and just by changing to this from another 98RON fuel, the car LEANED OUT BY A FULL AFR POINT (ie 12.5-13.5).
This would explain the increase in performance experienced by owners of cars with factory style rich tunes, but if your car is tuned on regular 98, and is "on the edge" I would steer clear, it could give you problems.
Joel, did you end up getting any? Do any logging of your car and the differences between fuels?
Are you kidding? How many Skylines or other imports out there actually don't have programmable ECUs these days. Surely only poofs own Skylines without prorammable ECUs :).
The ONLY reason people buy Power FCs etc is to reprogram fuel and ignition to make more power, this typically means more ignition advance and less fuel.....or have I misunderstood your statement that there are bugger all hard tuned import cars in SA?!?!?
....or did Nozilla say it?.....
well i run stanadard ecu at the moment so i guess i'm a poof, unlike your good self i don't make a heap of money so a programmable ecu hasn't come into my budget yet, i sincerely apologise! (if u couldn't tell i was bein sarcastic!)
  • 3 weeks later...
Got a tank of this at the moment, thought I'd give it a try
So far so good, knock levels on the PFC are much the same, and th weather has been a bit warmer the last few days too
Feels better than with BP 98 in it, more of a crispness to the exhaust note I reckon
Chops - what you said about the AFR's leaning out - would this have anything to do with the 10% ethanol content in the fuel not being able to be read by the current range of AFR meters used by dyno operators................
I spoke to a guy at the SAFF stand at the show, and he was saying they dyno tested the fuel on allot of cars, and they came to the conclusion that due to the ethanol content in the fuel, the AFR meters struggled to read this
My guess is Martins cars picked up power because he added fuel to compensate, and there is your power gain......
Most of the cars I have seen Martin tune, mine included, where quite lean, so by adding fuel to his tune, might xplain the power gain??
Also, ethanol, being like a alchohol, should cool the inlet charge a tad better than fuel when it gets injected shouldn't it?
Just my two cents!! :D
Ethanol contains oxygen (CH3CH2OH) and therefore the fuel provides some of the oxygen required for combusion itself.
Therefore, if tuning is not altered, for the same mass of air and fuel, there will be less unused fuel in the exhaust, which will be read as a "leaner AFR".
Yes, the cooling effect you explain also sounds likely.
Yeah, that was my thinking too
One thing I can report, as you pointed out, is that the economy seems to be poorer than that attained with Mobil or BP fuel
Either that, or my attempts to test its ability has meant I have driven the car a little harder :P
So far, its hard to say if its better or not, definatley a tad cheaper, but it looks like you burn more of it, so the cost advantage kinda cancels eachother out
Anyone else tried it?
I'm thinking it would be great stuff with a das of toluene in it.........
ethanol is a good knock retardation so you can run a bit more timing
ethanol contains oxygen so more fuel is needed compare to before
overall you will use more fuel than before but produce more power from more timing advance.
Fuel consumption will depends on your right foot.
I agree with 9krpm, the fact that Ethanol has more oxygen in it means it is has less potential to burn because it is already down the path of oxidation. Therefore more fuel is required for the same bang and the bang is smaller at the same time.
On balance, I reckon Ethanol in fuel is crap.
Toluene is good because it is hard to burn so you can then run more timing with a lower isk of pinging. It also produces a bang equivalent to or better than say straight 98 octane petrol. They say BP98 does not use aromatics (like Toluene) to achieve 98 octane, so when you do add Toluene in, the Octane rating increases more readily.
I was going to rig up a water + ethanol injection system for high boost.
The ethanol is a good knock retardant and also produce extra O2....just like NOS but not as good. A lot of people gain more power with the water + ethanol injection system by leaning the engine out a little bit more than normal. However with this fuel available from pump I don't have to worry about the plumbing work.
I think it's a great fuel and will give it a try soon. I am still worried about long distant or interstate trips. Does anyone know if this fuel is available in other states?
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
