What about a 265/35/18 then? i just wanted to get a wider tire so the rim doesnt stick out futher than the tyre wall and it wont look like the wheel sits in the guard as much,the 40 series is a much nicer ride on the road too coz i have all ikeya formula controll arms top and bottom around.
This is for the front will be rolling rear guards soon so i can fit my rears
Skyline model = R33 GTS-T 1997
Wheel diameter = 17"
Wheel width =9
Wheel offset =22
Tyre size =215/45
Modifications to fit = slightly lowered on coilovers still running splash guard
hey guys, Im trying to pick some new wheels n sizes. What's recommended for r33 gtst with standard suspension,
currently have 17 x 8fronts(not sure offsets), 17 x 9rears with 235.45.17 tyres and have heaps of clearance lol..
I would like to go for 19's or 18's dish type wheels but unsure of offsets, cambers and clearances. dont want to do any mods to fit and I will lower it with coilovers to suit after wheels fitted. Thanks for any help
ok lads, got new sizing in mind, and im gonna get the rears flared if need be cause this is the look i want
work emotion XD9's
rear: 18x10 + 18 225/40/18
front: 18x9 + 12 215/40/18
I will definitely be running some camber on the rear (bout 3 degs) and some on the front if need be...
how are these gonna fit mr nisskid?
work emotion XD9's
oh for a 33 gtst btw, with the rear guards rolled flat already
work emotion XD9's
very aggressive, very nice :down:
use camber adjustment to get the fitment just right.
work emotion XD9's
Hey Braddd, this is my first post and I don't want to come in too hard straight off the cuff, so forgive me if this sounds too authoritative, but you know thats not legal right?
225/40R18's shouldn't be mounted on anything bigger than a 9" wheel.
215/40R18's shouldn't be mounted on anything bigger than a 8.5" wheel.
with that in mind have you considered;
rear: 255/35R18
front: 225/40R18 or even a 235/35R18 (a bit hard to find)
its all about the stretch! haha
are you sure 225/40 is legal for 9" rim? i would have thought youd be pushing it..
bradd u wont need to flare rear just roll guards and camber should look tough as! ive got 18x10 +20 and i just rolled but havent dumped it yet may need more guard modification when i drop another inch.
also nisskid what are the chances of fitting a 255 or 265 under r33 guards lots of camber im guessing?
again, I'm not trying to be a smartarse here, just trying to provide some help... :P
According to the Tyre & Rim Association of Australia Standards Manual, which is what all state authorities reference on wheel & tyre standards, a 225/40R18 may only be mounted on a 7.5" - 9" wheel. (Nominal width is 8").
It's worth mentioning that this manual supercedes any claim made by a manufacturer regarding wheel width min-max.
This from the website:
The Standards Manual is a necessary reference for all tyre and wheel manufacturers and retailers, as well as vehicle and implement manufacturers, vehicle service organisations, transport authorities, government bodies, road and traffic authorities, fleet operators, agricultural vehicle and machinery users. Current Standards Manuals are a nominated standard for many Australian Design Rules (pertaining to the design and manufacture of automotive products) and State Transport and motor vehicle regulations.
is this manual what police will defect you via?
i got done on the weekend for a 235/40 on a 18x10 so now im thinking ill just stick the right size what is recommened for 10" in your book pls?
    • And one last super random thought, I remember when SAUNSW had a dinner with Alan Heaphy, and another with Fred Gibson there was talk of the R32 GTR cast alloy uprights failing in racing, and one of the things Fred did when they had to add weight to the vehicle was taken the failing alloy uprights, and have them made of steel. Does anyone remember back to 1990/1991/1992 and WHAT was failing in the front hubs/uprights?
    • If you truly want to know how the original failed though, was it a factory defect possibly etc, send it off for investigation. Would probably cost a shit tonne.   The ones that you need to win lotto for, unless you have a good reason for that part to be bolt on, I'd probably roll with getting a few small stitch welds carefully put in place as an extra safety factor once everything is all torqued up tight
    • Are you sure? Because I wouldn't necessarily be. Do we even know the material they've made the new uprights from?   Looking at the fractures in the earlier pics, it does to me look like both a twisting, and levering upward action doing the damage, so you're hoping for both compression, and tension. Depending on the bolts, they can stretch (even high grade bolts will) and now you're hoping for the threads themself not to stretch, as if they do, bye bye mating surfaces holding together, hello bolts now going into shear.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
