Hi guys,
can anyone tell me the offset that would fit flush with the 33 guards
front 18x8.5
rear 18x9.5
been reading this topic but just cant find it, always slightly in or out
+30
Hi, I need some advice on fitment.
Would it take a lot of work to fit something like F: 18x9.5 + 30 R:18x10 +30 to a 33 GTST?
Have Tein superstreets fitted.
Thanks for any help/advice you can give
will require guards rolled and slightly flared if the car is low. front liners will have to be removed.
the fronts will sit out 5mm less than this: (bearing in mind that i pulled the guards to exactly where i wanted them)
the rears will sit out 1mm more than this: (bearing in mind that i pulled the guards to exactly where i wanted them)
yes should be fairly ok, front might be slightly mexican but a good roll should fix that. back will be fairly easy with a roll only needed and maybe a 235 or 245 tyre depending how low your car is.
all gonna come down to car height on this one... i run fairly low, (320mm rear and 325) front so flaring was req'd with 235's and this is pretty much exactly the same
im sorry i dont follow 320mm what? off the ground?
30three- dont forget camber..
i've gone the less width way and more offset for the set i'm getting for my 33
they are 17x8 +5 on front and 17x9 +11 on rears.
currently they have 205/45r17s on front and 225/45r17 on rears. will see how they sit on stock guards with slightly lowered suspension but i'm thinking 215's atleast for front.
will update with picture i nthe next week ro so.
should be fine, maybe a little conservative if your going for flush look i think a few people are running 10" +22 but im not up with r34 fitment.
Think he means centre of wheel to guard. forgive my n00bness i dont know what that means still haha..
Hi guys,
I'm looking at some Tri spoke rims for my r33 gts-t. They're being sold without tyres. Basically, these are the specs:
17x9 20+ fronts
17x9 35+ rears
I know little about offset etc, but will these wheels suit my 33? Please bear in mind that the car is lowered slightly, but I do with to go lower down the track with coilovers etc.
well u'd want the higher offset rims on the fronts if anything and +35 9" wheels might scrubs on the inside if your low so test fit them first. 17x9 +20 should fit on the rears fine if you run a thin 235 or a 225 tyre.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
