oh wat yeah i no the feeling man im getting married in feb next year so i cant go that crazy with me car till after that, just want to get me injecters and comp so i can have some real fun lol, wat rimz ya getting or is it going to be a surprise.
Congrats. I've posted what I'm getting on sau somewhere but from now on it's a suprise lol :P
I was considering powder-coating my XT7s in black for my R34, but decided against it.
Now you're making me think about it again damn you lol.
But I must agree with previous comments......one of the toughest 33 GTS-T's around.
Just needs that front lip painted black to finish it off :P
Edited by BTM
235/40's and rolled guards and you can tuck that easy :)
Thanks for that, what about 18x9 +4 f and 18x10 +4 r would take fair bit of work to tuck them in hey?
i have a friend that has 18 9 with 0 offset they stick out a lil but all he did is rolled the guards flat and pulled the guards out a shit load by hand and it come up pretty good im running 18 9 +15 and i have only rolled the fronts a lil iv posted up pics just go back and have a look.
Fronts with a 215 or 225 would need a roll and pulling out, depending on height of course. Rear will need a roll and possibly a pull also depending on how much camber your going to run and how flush you want it. But it would look great lol
Mr Hamish,
You reckon you could tuck 18x9.5 +14 in your 33 as is with same size tyres you're using on SSR's?
easy... I have had 9.5+18's on there with no hastles
my new rims are gonna be 10+18's btw
dont forget my guards are pulled tho.... why?
9+4 would be doable on my rig, but 10+4 would need more flaring or camber.
still easily doable tho
Hamish,
I'm selling the GTR for another GTST, and I remember there's some room in your front guards when you have the professors in when I looked at it last.
So your answer is very useful, thanks for that, how much have you pulled the guards?
Cheers
Grant
  • 3 weeks later...
Hi All, I've read through this entire thread so I apologise in advance if I shouldn't ask this here (please direct me to the right spot)
I've come across some Works XD9's which are 18x9 +30 all round without tires. From everything I've read it seems these should fit fine on my R34 Sedan and will probably stick out about 5mm on the front? Anybody able to help with this?? Also they don't have tires, what's my best bet in terms of nice fitment?? (or is it best I just take the car to a tyre shop somewhere, I'm in Perth btw)
They are currently bronze but after seeing Blaqs I'm very tempted to go black also coz once you go black... =P
thanks in advance lads
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
