Got some 18x10.5 +20 for my r32 GTR.
Rear guards are rolled, anyone know if I will need to roll the front?
Tyres are 265 35, ride height is standard atm.
Cheers
You should be ok. They will stick out 2mm less than my 18 x 10 +12's. I've just lowered mine a bit more last night
And the only thing they started to hit was the inner liner on the drivers side. I'm gonna lift back up 10 mm all round.
hi guys, just wondering if 245/35s will fit on a 18x10" rim? without looking stupid... as i worked out my speedo will read more correct! as i currently run 245/40s and they are a little stretched and reads slow.
has anyone done this?
cheers..
Ok i've been through about 20 pages in the thread but can't find anyone that has put R34 GTR VSpec rims on an r32 GTST so just wondering if anyone has done it or if 18x9 +30 would fit on R32 GTST rear guards which have been pulled and rolled, I have GTR front guards which arn't rolled and pretty sure they would fit.
Thanks Tim.
How would 18X9.5 +15 Drifteks fit on a R33 GTS? Mods needed?
BTW I have slightly rolled guards and run about 2 degrees camber on rear and BC coilovers all around (pretty high atm)
Thanks in advanced :thumbsup:
Thanks Tim.
Tyre size? Fronts will be fine. Rears will be fine depending on camber / tyre size
Should be able to get away with a 225/40 tyre all round
Sorry, will try and get some pics up soon, turns out the retards that put them on at ozzy decide to put a 9.5 on the front left and a 10 on the front right, with a 9.5 on the rear right and a 10 on the rear left... f**ked up my alignment. thought it looked funny!
its sitting reasonably low, not where i want it though..
Skyline model = r33 gtst
Wheel diameter = 18
Wheel width =10 and 12
Wheel offset = -6/-17
Tyre size = 255 and 275 stretched on
Modifications to fit = rolled and flared all round + 50mm blot on flare + low camber
definately need pics!
you will have to take out the inner guard linings and depending how low you are you will have to move the wiring loom up. Also i had problems with scrubbing on full lock on the firewall which i bashed with a mallet to get more clearance.
i ran 18x10+10 with a 225/40 on the front
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
