For now I think I'll leave it as is.
Only to test the waters and see if I get any attention for having them.
Also my funds have dried up a little haha
I think the law is 25mm outside the guards? Not too sure on that one, is just what I heard.
I haven't got any cop attention at all, had cops pull up next to me and behind me.
But yeah the more you lower your car the more camber it will naturally give it. Anyway it does look boss man - check out my pics a few pages back - black on black, same rims haha.
EDIT: I see you commented on a pic of my car saying it was perfect fitment haha.
Edited by voncina
I saw in another thread on here where the guy rolled the front guard lip tight such that one of the tabs was holding the liner like a clamp. So basically kept the liners, and rolled tight. Not sure how robust that would be though.
Will see if i can find it again...
Found it:
http://www.skylinesaustralia.com/forums/topic/401848-trying-to-fit-my-dream-wheels-te37/page__view__findpost__p__6393854
You can see in one of the photo's how they used the tab to hold in the liner. Personally I would prefer to keep my liners when I roll. This looks like an option, but would be keen to hear others thoughts too.
in the pic below shows clearly that the tabs are not holding in the plastic guard liner (splash guard). Also looking at the pic seems it has a small flare pushing the guard out slightly
also this has not been rolled perfectly flat
Edited by Frosty
Put new wheels on today,(17x9+22 enkei rpf1s) and have ran into a slight problem, regarding those plastic guard liners.
They scrap on corners that have either got a bit of a dip during the apex or slight elevation or while descending.
If i remove them completely, is it possible for the wheel to still hit the guard at all? Am i able to push the guard out at all to stop this happening?
It used to happen even with stock R33 wheels as well. Any info would be great.
Car had an alignment today, it was only slightly out.
The car is sitting on bilsteins and king springs, it isn't as low as others i have seen, i can stick my foot between the wheel and the guard. With the new wheels pretty easily, at slow speeds aka 50kmh, on the stockies it did it only on corners that had a really bad dip during the apex (only in the hills), when the G's would have been at there highest.
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
