Im looking at some LMGT4 18 x 8.5 +20 and 18 x 9.5 +30 rears
looking at fitting the widest tyre possible without too much rubbing. Will the front have any poke or need camber at all to fit a 245 atleast.
Edited by B-rice
I had 245/40 on my old 17x9, my definition of stretch is different to yours of course.
265/35/18 on 18x10
Same size on 18x9
Each to their own
profiles are different... I said 235/45 as it's the most common size, you are talking about 235/40, which is more expensive and is always going to be more stretched as the sidewall is 5% shorter
also i'm not sure the relevance of a pic of a 265/35 on an 18x10
fwiw 235 on a 9 is well within the legal range too :)
no
I've had 245/40 and 245/45 on my 17x9 wheels and were stretched. 265/35 on my 18x10 are stretched, but my definition of stretch would be different to say, yours, I'm guessing. I didn't say anything about 235/40 :unsure: . The person asking didn't say anything about prices, plus 245/40/17 aren't as expensive these days. Yes 235/45/17 is cheaper as it's way more popular. That being said, would you want to run wider tyres that fit into the guards? I'm going to run 255/40/17 on the back of my R31 (17x9 wheels).
Picture was relevant to my "stretch" point (sidewall angle). 245 is slight stretch, 235 would be even more (that was my point).
Plus, 245/40 on a 17x9 +22 was made to fit on my mate's S14 with rolled guards, so that is a real world example (unless S14 guards have more clearance than R32).
hi everyone been reading for a while but not much on rotas
i have decided i would buy Rota-G force.
I want something that sits flush.dont mind if guard rolling is needed
dont want camber or anything like that n the car is still on stock springs
these are the set's that around what i wud like
18 x 9, +35
18 x 9, +27
18x9.5
what offset would look good ?
cheers :)
Sorry:/
Well some guy is selling rims he had on his 350z & they look really nice
I'm thinking of buying them.
18x10+ 12 rears
18x9.5+ 20 fronts
Rota is the brand
What sorts of problems will I come across to get them to fit?
Any help would be great:)
Cheers
will need to roll guards and camber
OR
roll and pull guards a little (flareing not reqired if you run like 245's on the 10's and 225/235's on the 9.5's)
OR
flare both guards to ensure the rims can fit and run the apropriate ammount of rubber
OR
run at landcruiser height
guard liners will have to be reomved to flare the fronts also if you want to go low
Can guard liners be retained if you just roll the fronts and not flare? Is there any benefit to doing so, or does it just lessen clearance?
they can however it's better to remove them as the bolts that hold them in are pretty good as catching tyres if the car is low
also clearace is an issue... my tyres would hit the metal above on occasion so liners would have been destroyed anyway...
also it's a good idea to jimmy up something to hold the cables out of the way in the right front arch
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
