hey all,
just a quick question.i read a thread somewhere,and someone that owned a gtr said that there standard bovs are really loud and make a good sound.not that i am 1 to care about the sound,its just mine only ever are heard when its dead quiet?my car is only running standrd boost,airbox etc?is that right for them not to be heard?or are they not doing the job?
also i no there plumb back?but as i said the bloke said hes was loud.cheers gun32gtr
also did a search and nothing was being found
https://www.sau.com.au/forums/topic/84656-gtr-bovs/
stick some pods on, and a bit more boost and then you'll hear em :rolleyes:
The airbox makes it all quiet indeed
some gtrs with the 2530's ive seen/been in can get the BOV's going off in sequence. Seen it on stock turbo'd gtrs too. Its really quite interesting and funny to hear , hard to describe.... all the while you get the benefits of the best BOV's you could b using.
https://www.sau.com.au/forums/topic/84656-gtr-bovs/#findComment-1532555
mine has pods and stock boost (and 1 bar), its a really short and fast release, like a PSSHOW, annoying when u are on the freeway and going up an incline and it keeps bouncing on the BOVS...hehe but yeah, pods should make it louder
lol, need a "describe your BOV's noise with letters" thread :P
https://www.sau.com.au/forums/topic/84656-gtr-bovs/#findComment-1533088
My bov are plumb back and they sound like "pooooofr" lol,
something like that, but it not loud or anything. So I am very happy with the stock bov.
I've know ppls with skylines and other turbo car using their bov to intimidate other cars, as "I have a turbo" lol
Damn, I hate the high ptich noise of some of the aftermarket ones makes.
https://www.sau.com.au/forums/topic/84656-gtr-bovs/#findComment-1533775
thanks for all the feed back fellaS....i was thinking of getting some pods for the gtr soon anyway,but dont think i will trust the turbos with anymore than standrd boost at the moment as i dont have the $$$$$$ to put some new ones on..the sound it makes i cANT for the life of me describe,but thanks again?
also if ne ones knows of some pods for sale good ones please pm me cheers kane.
anyone else want to describe there bov sound lol
https://www.sau.com.au/forums/topic/84656-gtr-bovs/#findComment-1533964
I couldn't hear any induction noise on my 34 GTR until i removed the factory wheel arch intake plug (airbox is plumbed into the wheel arch and front bar on 33s and 34s - not sure about that on 32s - they plug the wheel arch hole from the factory for noise emission purposes).
After I removed it i could hear a lot of induction noise and quite a loud noise from the blow off valves. When driving up hill on boost if you back off the throttle a little bit but not all the way you will hear the valves firing seperately.
https://www.sau.com.au/forums/topic/84656-gtr-bovs/#findComment-1537364
I describe it as a "choofle", if that makes sense.
I could drive around choofleing all day, and it does sound pretty good on the right revs when goin up a hill and accelerating a bit then backing off(choofle-oofle-oofle), but it gets pretty annoying if you're trying to maintain a certain speed. Oh, the prices we pay to drive supercars.
https://www.sau.com.au/forums/topic/84656-gtr-bovs/#findComment-1537443
yeh thts more the sound i could not right it....so what pods does everyone use mainly,as in which are the best????????
also what this wheel arch hole u can remove,i thought i most well take it of its easy,as i have the front bar off
https://www.sau.com.au/forums/topic/84656-gtr-bovs/#findComment-1537924
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
