just wondering on this subject, i have my 33 off the road doing up all fancy interior bits and stuff.. i took the back pannel off the other day and im wondering how easy it is to get the light up skyline badge on it... or is that a completly different item? is it as simple as just slipping a neon in somehow?
  • 11 months later...
I'm also interesting in getting the 'SKYLINE' lit up as well. I remember that there used to be a tutorial around here somewhere, but I have spent the last hour searching and came up with nothing.
Cheers.
to make it el glow http://www.luminousfilm.com/ im sure u can find wat u need. u will also need an inverter as el needs ac volt to work. maybe if i decide to do mine i will make a tutorial. this should help to get you started.
Edited by DazWah
  • 1 month later...
hey. i tryed this on a`series2, but it will not pull out. does this just pull out?, felt like it would not even move?
Have you removed the 4 nuts from the inside of the boot?
Then there are about 3 clips holding it in place, which come off easily
i just started doing this, loox good. ill post my pix up later when it all drys. i done black gloss on a silver garnish. i found it beta to tape arond the letters first, then sand it, that way you could sand the edges of the letters were some of the tape may of grabed, then you can paint the hole 3d leters perfect on the sides as well. :yes:
  • 2 years later...
i just finished painting my rear garnish :( black and the badge "chrome". Its beautiful (well it was till i ruined it by tryin 2 remove a bit of tape glue tht was left behind :) ) anyways.. goin to have to redo again because i dont like the so called chrome paint. its more of a shiny silver. Ive looked around as well to find nothing.
any ideas where i can get sum decent chrome paint or whatever it is?
hey, ive tryed all the chrome paint.. it will come out shinny silveer.. and some times depends on the surface.. i found a rock comes out shinny with chrome paint.. i got mine from buinnings.. but, the only way to get chrome effect is to get it chrome dipped.. i re-searched for months and kepts my eyes out for 2 yers.. hope it helps a bit...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
