Hi all, i'm not sure if this should go in this area or not, so please forgive my ignorance.
Basically the situation is this:
I am looking at buying a car off of a guy who had the car imported into Australia about a month ago, its an R33, and it has a compliance plate etc.
The car has never been registered and he's selling it, as he had bought another car.
Naturally I'm getting the car a complete mechanical inspection, but apart from this and the compliance plate on the car. What else would I need to get this car registered in Queensland.
As far as I can tell from the Department of Transport Website, what you need for registration first time in Australia is: The compliance plate on the car, A proof of purchase, A saftey certificate, CTP insurance from a provider (AAMI etc), and to fill out the registration form. Oh and also proof of identity and address etc. Is that all correct?
What I want to know is, will a bill of sale suffice as a proof of purchase? Do I need anything else? IE: all the papers etc from importation? Is there anything else anyone thinks I should do/get/check out before I go ahead with anything?
Thanks in Advance, Tom
BTW: Under SEVS, does the car have to have verified KM's? or if it was sold through Auction in japan verified?? From what I understand Auction houses in Japan have to show clear title before they can be sold?
Thanks again.
https://www.sau.com.au/forums/topic/85051-registration-issues/
Ask for ALL the importation papers for the car - the other party has no reason to keep them anyway.
This includes: Japanese 'dereg' paper, purchase document from Japan, copy of the Import Approval, receipts and the information from the RAWS showing that the vehicle was complied, shipping document, auction sheet for the car.
BTW, on the DOTARS website you can enter the VIN of the car and it will bring up details of the RAWS that did compliance and other info for the car so I'd double check that to be safe.
Regarding the km - there's no 100% foolproof way to prove that the km are genuine when a car is imported - things like original logbooks and service receipts help though.Sometimes in auctions if they think something is suspicious it will be noted on the auction sheet.
mate what you have said in your first post is all that you need.
once you have the car in your possession, all you need to do is what u said, have all papers with you, receipt form CTP company and you can drive your car to get a safety certificate done n then you can drive from there to the registration place.
then your ready to have heaps of fun ;)
whats the website for that DOTARS sote?
http://raws.dotars.gov.au/rawswebpublic/RAWPubVehSearch.asp
If your car was brought in under another scheme (eg the old CPA scheme), then it won't show up.
Vijay
if your still looking into a fresh import, make sure that the compliance was done pretty recently (at least in Victoria), because the compliance certificate is only valid for a month after it was issued. Otherwise you'll have to have it re-engineered...
Edited by foznice
well i thought id be more helpful
I needed:
Import Approval (for 15years) 1990
QLD Saftey Certificate
QLD Mod Plate - for car mods
CTP certificate
if its a sevs car, yours will be you will need the compliance plate and compliance doscumentation.
(mind you I had my compliance enginners report and they didnt want to see it)
This was at Spring Hill QLD Roads in Brissy.
besides that just your license for ID and proff of address etc.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
