  • 1 year later...
I just installed a cd/dvd/tv unit as well and I am wanting to hook up a reversing camera. Does anyone know which wire I need to attach the unit to to switch to the camera when I hit reverse?
Cheers
i powered my cam from the reverse lights in the rear door as i mounted mine just under the handle.
cool cheers, I was thinking I might put it there. I can use the reverse light wire at the rear to power the camera. However what about the trigger wire from the head unit? Where abouts is the reverse light wire in the dash? Is it under the centre console? Which color? (I haven't had a look yet, so it may be obvious to me when I take it out next. I just thought someone may be able to save me the trouble)
Thanks again
:P
  • 2 months later...
Can i get some kind of confirmation on the stereo wiring for the S2? Or if anyone knows of a adaptor kit?
I ask as i am lookign at a 2 din hole with two blank connectors, and i know i have 6 speakers (2 pillar tweeters).
Thanks in advance!
just a question for everyone in here who has taken there dash apart a few times, does anyone else have spastic cup holders? what did you do to fix them? mine sort of work but they hang to one side and look funy.
Thanks in advance!
You will only have 4 pairs of speaker wires, the A pillar speakers are "splits" with the front door speakers.
Has anyone put a double din head unit into a C34? Just wondering if there are any issues with it.
I've done it . Absolutely no probs, just follow the DIY. Get a plug to suit from JB, cut and solder.
Edited by 66yostagea
Thanks to STAGE-A for the wiring
12V ------- Brown with white stripe
Ignition -------- light blue with yellow stripe
Lights -------- Red with blue stripe
Earth -------- Just use the stereo metal brackets
and heres the speaker connection wires (stagea s1 at least)
left front ---- blue (+) black with white stripe (-)
right front ---- brown (+) black with red stripe (-)
left rear ----- mint green (+) black with yellow stripe (-)
right rear ---- orange (+) black with pink stripe (-)
On my S2, i found the RL & RR polarity was reversed to the above stated. and i also had two spare wires :)
  • 2 months later...
installed a new HU on the weekend
bought the Aerpro antenna adaptor, and found i got good reception even without combining both the antenna's
spliced into the black/yellow wire, and it seems radio reception is fine, haven't tested extensively yet
ran the ipod cable into the centre console, and a bluetooth mic into the exmpty switch next to the rear demister
lots of fun to work with. . . not!
  • 3 months later...
Quick question I need clarification on...
Will an S1 Xanavi unit be a direct swap into an S2 with the Factory CD/cas unit?
I believe it will. But why would you want the Xanavi unit anyhow?
just to let everyone know, there is probably an adaptor from aerpro that will plug into the stock harness
i dont know what the part number is but my r32 took the same part as a gq patrol which is about the same age so i would suspect that an adaptor is available to prevent having to cut and solder and also save time
Interesting...so Does the S2 car that has xanavi use the same looms/wires/sockets or whatever for air-conditioning... as one that didn't come stock with the xanavi unit?
No it does not.
One would require something like this: http://page5.auctions.yahoo.co.jp/jp/auction/e93993162
Ahh bugger. I'll be needing to buy one of them. Could you tell me the name of it so i know what to search for when it comes time.. please. haha
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
