ok now ive just read through this whole thread and im still lost, ive got a factory tape deck/stacker setup, ive got the plug with the 4 wires that someone said was for satnav plugged into my headunit, so ive got 3 plugs in the head unit and one empty socket, i also have a round socket 5 or 7 pin i think, with nothing plugged in to it. there was also a frequency expander in there that the plug broke off when i was poking around. and there is an extra plug in there going no where. can anyone shed some light on this??
Take some photos and post them up, it will make things easier to identify and get help! :P
The round plug is an 8 pin Din plug, that connects the Xanavi to the HU. Supplies the audio from Xanavi, Combo power on trigger, Aux on trigger and the Aux request wire.
The Left hand lower plug is the constant power, ignition on, and the LH/RH speaker wire. I can't remember whether it's front or rear. The right hand plug with 4 wires is the LH/RH speaker wires. Again, I'm not sure whether it's front or rear. The top left plug is the plug that goes off to the stacker. Do you have a patch lead between the main chassis loom and the bottom left plug? You may find that you do and it'll have 2 wires a yellow and red. The is the constant and ignition wire for the stacker.
yer that would all make sense, now i just need to work out why my climate control light on one end has gone out. there is also 2 diffrent plugs in behind my headunit that are just sitting there on the loom goin no where, one looks like it might be for the ok meter type guages that replace the clock but thats just a guess. does anyone know if the stacker will work with newer clarion head units? i just dont want to take it out and have nothing in the whole.
  • 3 months later...
i'm in the midst of installing my dvd/tv double din stereo
reception is rather poor although i hooked up the amp wire to the black with yellow
well actually i spliced it into the loom and left the plug connected.
the old FM converter was spliced into the nearby constant acc power for the ciggy lighter, so after reading THE WHOLE THEAD and not just the first 4 pages i'm going to separate the loom and try running 12v acc to the black with yellow.
the unit i have has digital tv and i have put the arial into the roof above the hoodlining - but i can only get abc 1 2 3 and 24 and with a rather weak signal. i'm a little reluctant to mount it on the outside of the car as the cable is not very long and therefore i cant put it near the back wing like i had hoped.
where has everyone else hooked their arials for DVB???
i'll post an image if the unit in the day light tomorrow - but while i have it out i'll finally wire the boost guage i have up to power as its been 3 months with no guage at night lol!
wires as stated in first post were same for series 2 and never double checked them, just spliced them into a new loon and plugged it in (put the old one in later if i wish)
thanks heaps for this DIY!
  • 5 months later...
Sorry to bring up an old thread, but i just ripped out my head unit to reroute the ipod cable, and moved the cable and now its not working. tested the connections with a multi meter, and i have Constant but cant get 12v+ to the stereo? Any help would be great.
You mean you have no 12V at the supply to the stereo? Have you checked the fuse in the fuse box? Also check the inline fuse in the wiring behind the stereo. You might have shorted something and blown the fuse.
I have replaced the fuse in the fusebox as that was blown, where abouts is the inline fuse? How far in behind the stereo?
i think he's talking about in line of the power wire coming from your hu
it may or may not have a fuse there also
or perhaps there's a fuse directly in the hu?
So is there any other fuse or anything i could have tripped other than the audio fuse in the engine bay? Becuase i get 12V+ at the fuse , i also get 12v constant from the brown plug i just cant get acc to turn on.
Edited by 4door31
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
