semi-slicks
Nitto 555R's are THE best you can get, no doubt. All the big names use them, especially Veilside. However, as far as i know they're not actually legal in Australia, so therefore you'd have to have connections to get hold of some. They're the best semi-slick to get, if you can get hold of them.
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-125529
Nitto's are one of the only drag specialised R comp that i know of. The others are made for track work, simple as that. Ideally if you want to get good drag times, get 2 cheap rims and a pair of fully slick tyres.
R comps wont provide you with that much extra, compared to a pair of full slicks on the back. And the slicks would probably cost less than 4 R comps.
I once saw a HSV ute with Potenza 540's on it down at the Motorplex, he was doing burnouts before each run, over heating the tyres and running the same times as he was on street tyres. They didnt last very long either.
Red17
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-126766
Go & compare the price difference btw Nitto's & RE540S's! HUGE difference & not in the Nitto's favour.
RE540S's cost me $1180 balanced & fitted (235/45/17 - 255/40/17)
Yokohama A032R's & Dunlop D01J's were both considerably more expensive, but compared to Nitto's they were dirt-cheap!!!
Having physically compared the Nitto NT555 & RE540S I can say they are pretty much the same in tread softness, it's the soft sidewall that gives the Nitto its drag abilities. Trust me when I say the RE540S is VERY grippy in a straight line for a cornering tyre. If you want to run decent 1/4 times on a street legal tyre & don't want to spent big $$$ give any of the A032R, D01J, RE540S rubber a go.
Doing big burnouts on the RE540S isn't needed, & as the HSV owner @ the 'plex proved it'll ruin any advantage the soft treaded RE540S gives.
The problem I see in running with full slicks is it's no longer a *street* set-up (i.e. HPI challenge) IMHO
Here's a thread I started a while back - http://www.skylinesaustralia.com/forums/sh...ighlight=RE540S
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-127856
Ahh yes, i guess thats the problem, its the old racing rules they catch ya with. I figured the guy just wanted to get the best time possible.
In that case, certainly, treating a set of R comps properly is no doubt ALOT better than street tyres.
And youre right, the Nitto's are ridiculously priced :D
Red17
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-127894
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
