Already spoke bout my results in silvar33 post but as i promised i would put up my results again with a graph. I had it tuned at chasers and im happy with the results.
231.1rwkw
hks 2535
pfc
z32 afm
nismo fpr
bosch 044 fuel pump
(standard internals & standard injectors)
results were achieved in shoot-out mode
very happy with the car now and makes more power everywhere.
tune is very safe, injectors only getting 85-90% and knock not getting above 15-16
https://www.sau.com.au/forums/topic/85398-2311rwkw-with-hks-2535/
231.1rwkw
hks 2535
pfc
z32 afm
nismo fpr
bosch 044 fuel pump
Excellent result, and it really is 231.1 rwkw at 13 psi. The 231 rwkw out of the standard injectors is right up there, what sort of fuel pressure is it running to get that much out of the injectors?
I am targetting 200 4wkw out of the Stagea (equiv to 215-220 rwkw) and I am curious as to the fuel pressure I might need to run.
;) cheers :)
im a tight ass uni student
to get me these results it cost me jack
pfc $980 delivered
nismo fpr $155 delivered
hks 2535 $1300 exchange
z32 afm $230 delivered
tuning $500
total $3150-3200
installed turbo myself
already had:
3" exhaust
bosch 044 pump
surge tank
5 puk clutch
simple crap (boost controller, pod filter, bov)
no idea wat pressure in fuel rail (maybe 38psi)
I also have a similar setup, any idea what sort of boost the 2535 is most efficient at? is it 1Bar/14.5 PSI or even more?
Im waiting for a retune as soon as I get new coil packs right now its sitting on 12PSI, not sure how much boost I should be asking from a internally standard RB25
http://www.skylinesaustralia.com/forums/in...=ST&f=8&t=83883
SK
i made 218.7 rwkw on the stock turbo with the stocko injectors, only added a nismo fuel pump and a sard fuel pressure regulator, i think my mechanic said he wound up the pressure 4 psi, not sure, i'll see tommorow what my injectors hit when boost maxs at 1.1 bar, will let u know
but i know he didn't wind much more into it,
nice figures you got there.
I hate all you peeps with Rb25's.
Its not fair :D
Mine goes in to get tuned in the next couple of weeks and im looking for 220rwk's out of the lil ol Rb20 thumper :)
Cheers B
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
    • This thread keps giving with the OMG!
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
