Hiya sydneykid,this be my firsty ever SAU post.Just signed up.
Anywayz I have an R32 GTS4 which is currently suspended by Skippy the Bush Kangaroo on Acid.Not my choice.Was like that when I bought it a week ago.
Sooo,what I want to know is can you supply a kit to sort this evil critter out.I want everything and I want it now.What do you recommend.The car is for road use.Will be contacting GTRgeoff for one of his HICAS lock bars.I intend to do it all once and do it right before I spend all my money misbehaving.Also if you can recommend a workshop in SE Qld that would be great.
PM on its way
:P cheers :P
  • Replies 714
Posted Images
Ok, so I've finally found the right thread to post in... SOrry about this... I'll learn to read a little more before posting.
hey sk...
My JIC coilovers are rattling and looks like they need a rebuild. I need to get rid of them I think. Mackay has really shitty roads, but I like a low car. Is there a setup possible for this? I like my car at a weird height - the Front slightly lower then the back (looks meaner I think heh)
Anyway, for the moment I just want to replace the coilovers because the cash storage isn't that great at the moment. Its a 1996 GTS-T so it hasn't worn many of the parts out just yet.. (pedders checked)
What would you suggest? I attached a few pics of the car to give you some idea of the height.
The measurements at the moment are (from center of wheel to edge of guard)
Back - 335mm
Front - 320mm
Hope I'm not being a pain in the ass.
What will I need?
hey sk...
Back - 335mm
Front - 320mm
What will I need?
hey sk, are you able to help.. Sorry if I'm being pushy.
PM sent
:thumbsup: cheers :no:
PS, sorry for the delay, people who send PM's get answered first, questions in posts come second.
Edited by Sydneykid
PM sent
:laugh: cheers :woot:
thats cool.
Hey, do you have a recommended Height setup between front and back?
For example, my front and back heights are 15mm different (back is higher), could this cause issues with types of driving eg. Dragstrip, and daily driving?
Front Castor Kits. Are they adjustable or preset at 7 deg?? Will they only work with the Bilsteins or can they be used in conjunction with stock or other coilovers?
thats cool.
Gidday Mafia, this is Garys recommended settings which you can get with this kit
For the street here are my recommended settings;
Front Camber -1.00
Front Caster +7.00 (slightly more on the left to offset the drift to the gutter)
Front Toe 0.00
Rear Camber -0.5
Rear Toe 2.00 mm in on each side
For the track;
Front Camber -2.50
Front Caster +7.00 (or more if you can get it)
Front Toe 2 mm out each side
Rear Camber -1.25
As you can see the big change is camber, what most the guys do (me included) is to use the Whiteline camber kits to adjust the camber when they have the car jacked up to put the track tyres on. Just get the wheel aligner to mark the amount of rotation you need for the 2 settings. Then you simply rotate the offset bush for the right amount (track or road).
The Group Buy Bilsteins have additional circlip grooves added so you can set the height you want before you fit them. There are 6 grooves 8 mm apart and I can tell you the height that you will get from each groove. Keep in mind that GTSTs handle best around 350 mm front and 340 mm rear (centre of wheel to guard).
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
