I just fitted a Hybrid FMIC to my Series II Skyline, Now my problem is my car is now running ridiculous amount on boost roughly 15-20psi when I look at my boost gauge, which I know its un-safe for my stock turbo, when I hit 3,500 revs my car spools to boost then my car starts to jerk so I keep my revs down low, I've only got a FMIC, turbo back exhaust, and af, no boost controller. I'm wondering if anyone esle has this similar problem that could shed some light and tell me whats wrong with my car.
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/
sounds like youve left off the cooler to actuator pressure line off, so the actuator never opens so the wastegate never opens, aka boost keeps climbing for ever. this can be fatal so be careful. check your lines and the air tubes running to the turbo area
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1548629
Hey, Ive also just fitted a hybrid cooler to my R33 with standard turbo, turbo back exhaust, bleeder valve, and mine does the same thing, except i run low boost (9psi), and it still jerks at high revs???? Could this mean I need to get a bigger fuel pump, or Do I need a fuel cut defender fitted. Ive checked for any boost leaks and still cant figure it out. Would a electronic boost controller fix this problem or power fc????
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1549352
Could be richening up to much in which case you would need a SAFC or Power FC you. Either that or you may have faulty coils.
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1550153
G'day,
I think I know what your prob is mate, When you removed the standard piping you cut into the vacuum line running of your standard intercooler pipe but prob did not plug this back into another vac line somewhere so you will have full boost, this is very very bad, dont drive it. T into your inlet manifold somewhere ie BOV so the wastegate can read some boost. This will fix your problem.
Cheers
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1550215
Im no expert on this sorta stuff? what do i have to do? sorry if im sounding stupid but Im worried about my car.
Did you put the cooler pipes in yourself? There is usually a vacuum hose nipple on the standard cooler pipe which leeds to the wastegate which hangs of the turbo. Because you have changed this pipe you will have to find somewhere where the wastegate can read boost from, Cut your BOV vacuum hose and tee of that into the satandard t piece off the wastegate and hook it up. If this is already hooked up then your problem lies elsewhere.
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1551104
I had the same problem with my skyline i fitted a front mount intercooler and the car wont rev past 3500 i changed the spark plugs and gapped them to 0.8 once i put them in started the car i could tell that the idle was better when i drove it it went hard, very hard so it solved my problem try that first, Always try the easy stuff first i learnt that the hard way
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1551907
hey guys! im in the middle of installing my Hybrid if anyone could post pics of where they have connected there line to there BOV then that would be good also if you have any pics showing what the piping and intercooler looks like as an end result.
cheers
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1557624
cheers
I went the all cheap kit cost me around $600 and works like magic can feel the power straight away but the car is running rich and is dumping fuel so ill need to tune the air fuel ratios. Just cut the BOV vacuum hose and tee into that it easy. I think you actually get a better reading from the original spot so n the future im gonna weld in a nipple to my piping.
Heres some pics.
https://www.sau.com.au/forums/topic/85500-just-fitted-fmic/#findComment-1557680
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
