hey gary,
has anyone else experienced difficulty fitting front bushes into the stock clamps?
do you require a whiteline clamp as well to suit the bnf28 bar?
cheers
The Whiteline polyurethane D bushes are a tight fit into the standard D brackets. It has happened (very infrequently) that Whiteline have supplied the wrong D bushes with the bar. A couple of quick tests;
1. Try fitting one of the D bushes to a D bracket, without the bar in the D bush. It should fit easily, with only very mild distortion of its moulded shape.
2. Next try fitting one of the D bushes to the bar, without the D bush being in the D bracket. It should fit easily, with only a very small gap where the bush is cut.
If the above tests indicate problems, D bushes usually have a part number moulded into the flat side. What is it on the bushes you have?
:laugh: cheers :)
:happy: cheers :D
Thanks Gary,
The D-bush i have has #1484/24 stamped onto top.
The bar that came off my r32 was only 20mm im not sure if that has created the problem or not.
I have managed to fit it with a couple of mods;
1- I ground down the top of the D-bush approx. 2mm
2- I then added 5mm spacers between the D-bracket and chassis
I also sanded off the paint which adds up to 1mm thickness
The bar fits in perfectly now, not too tight that it looks like it is binding up.
I couldnt start any of the bolts before!
Cheers
Thanks Gary,
Cheers
The bush part #1484/24 is the correct one and I haven't had anyone else report issue like this. As I said, they are a tight fit, but your level of required mods seems excessive, 1 mm + 2 mm + 5 mm = 8mm too big, that's way over the top. I will have Whiteline check the dimensions of the 1484/24 just to make sure that there is no moulding error.
:) cheers :)
Bilstein Australia have received a small shipment of R32GTST rear shocks. Those guys with back orders, I will be contacting you tomorrow regarding delivery of your shocks. Thank you for being patient. Anyone thinking of buying a kit, my best suggestion is to get in now, they won't last very long.
:P cheers :happy:
Gary,
I haven't heard from you and want to confirm that I am on the list as I placed my order in December when there was only 1 rear shock left. I may be jumping the gun but I'm getting a little nervous as I haven't received a PM from you.
Thanks.
Gary,
Thanks.
PM Sent
:( cheers :mellow:
Any chance of the Bilstein/Eibach coilovers like in the S14/S15 groupbuys?
I.e. A more track oriented setup
Yes, just ask, plenty of guys have.
The reason for the S13/14/15 coil overs is to allow height adjustment. Which the Skylines don't need, as the additional cirlcip grooves on the Bilstein shocks provide that facility.
:( cheers :ninja:
Sorry all, I have been out of action for 3 days, somebody gave me a nice little virus. So the PM inbox filled up, but it has been cleared now. So if you could n’t get a message though over the last couple of days please try again.
For those that did get a PM in before the overflow, please be patient I will get to them all sometime today (or tonight).
:laugh: Cheers :rant:
I am off to Bathurst tomorrow for the 12 Hour race, the race team is running (not a Skyline) and I have to do my Team Manager thing. I will be back on Tuesday, so please excuse the slow responses to posts and PM's.
:pirate: cheers :ph34r:
Hi SK,
Been looking at this group buy for a while now.. Was wondering if you'd be able to do anything the same in New Zealand? Understand it's not probably the easiest but i've been looking for one of these setups for a while (I quite like Whiteline gear) even if I can get the Bilstiens revalved over here or similar.. Or any idea about freight from AU > NZ?
Thanks,
Scott R
is it possible to get a price on whiteline control springs to suit a soarer?
Same Group Buy price, $144 a pair plus $10 freight.
If you are contemplating using standard shocks & lowered springs, I suggest you have a read of this thread.
http://www.skylinesaustralia.com/forums/in...c=103158&hl
:laugh: cheers :P
Guest carasky
hi i am new to this forum and i was wanting to know how much it will be to get front and rear shocks and springs for my series 2 r33 skyline coupe. This car is a daily driver so i dont want no drift setup just something nice and tight wat do you recommend and how much i ready to purchase...thanks
PM sent
:) cheers :thumbsup:
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
