Hi Skyliner's, I am selling off the remainder of a 95' R33 Gtst Coupe that was unable to be complied under the new RAWS regulations. I have many parts left, ie Interior, some mechanical, rear windscreen and qtr glass, etc.
Email me what you need, [email protected] and I'll endeavour to get back to you in the evenings.
Leave me your email address if you want more info, including price.
SJ
Edited by rdirty32
https://www.sau.com.au/forums/topic/85797-wrecking-r33-coupe/
  • Replies 50
Hi Nath,
The reason I haven't listed all of the parts is that I'm not sure as to what parts I have kept after stripping the car. The body shell had to be destroyed by law, which left me with various parts that I am now clearing out. I would love to be able to list all of the parts, but it would take me a few days to confirm exactly what I have, and lets face it, there are some parts that will never be required by anyone.
The way I see it is, make me an offer on a part that I have, and then everyones happy.
I hope this explains my situation.
Cheers, SJ
Do you still have any of the following;
- Handbrake cable & Lever
- Pedals
- Clutch master cyl
Did it have good suspension? If so, how much for the rear only?
Prices pls, thanks :P
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
