Looking for rear springs for my R32GTR - want a spring rate of ~250lbs, 60/61mm ID, free height of around 250mm (?) with tender coils.
What's the difference between the three spring manufacturers?
King 'pro sport' coil springs are 'Hot rolled, oil quenched and tempered', whereas Whiteline race springs are 'chrome cold wound'... what's the go with them?
Questions:
1. will i get away with a shorter spring, say 220mm, with using tenders as well
2. two choices will be
Kings - KPS-042 250mm free height, 250lb
Whiteline - CS61220045 220mm free height, 252lb
are they more or less both the same?
3. do lovells make linear rate 60ID springs?
Cheers in advance
https://www.sau.com.au/forums/topic/85845-king-whiteline-lovells-springs/
As always, i recall Sydneykid posted on the subject ages ago, i cant recall the exact differences myself, other then the rate of cooling/quenching affects the grain structure after being heated beyond a metals eutectic point (does it get heated that high???) so requires controlled cooling to stop the grain structure from becoming too martensitic and becoming brittle.
Cold working also has dramas, and requires a steel with slightly different mechanical properties, and cold workign normally hardens the metal...so there is a trade off in there as well when the spring will have very high cyclic loads and likely heat up during operation.
LOL...i bet i have confused martensite with austenite etc...i cant remember that crap. i bet GTR_Geoff or someone else knows it off the tops of their heads though
I will avoid the metallurgy. Whitleine use cold winding spring steel from BHP (to the German Standard) , it is specifically designed for the cold winding of coils and to maintain its grain structure during that process. This requires high powered hydraulic coil winders. This the same basic steel specification as used by Eibach, Jamex, Koni, Bilstein etc This process is good if you are making small batch runs, as the set up time for different coils is short.
Kings, on the other hand, use spring steel, also from BHP, that is designed for hot winding. This requires a much lower powered coil winder, but tempering is an additional step in the process. Many OEM coils are made this way as the process is good for long batch runs, due to the longer (than cold winding) set up time.
The bottom line is, neither process is technically superior as long as the procedures (for that grade of spring steel) are followed.
:rolleyes: cheers :)
Thanks Gary,
My other questions was, is there any problem with going to a shorter spring (from 250 to 220mm) if I am using tender coils and have plenty of threaded shock body to wind the lower spring seats up a bit?
cheers, marcus
Thanks Gary,
cheers, marcus
No, just be aware of the increased potential for coil bind and make sure the bump stops prevent it. Coil springs don't like coil bind.
:D cheers ;)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
