Bridgestone Re55 Prices From Donnellans Box Hill.
Hey guys,
Mark Donnellan has asked me to update the discounted prices for Bridgestone RE55's. The price has increased slightly for some sizes. If the size you want is not listed below, contact Mark to enquire and mention Skylines Australia.
Since the other thread was closed I've started a new one with the current prices. DO NOT WHORE THIS THREAD.
Details:
Contact Person: Mark Donnellan
Donnellan's Box Hill (Bridgestone Tyre Centre)
837 Whitehorse Road, Box Hill
Ph: (03) 9898 9591
Melway Ref: Page 47 B9
UBD map ref: Page 256 N14
Prices:
[ 18" tyres ]
Bridgestone RE55 225/40/18 . . . . . . . $376 per tyre
Bridgestone RE55 245/40/18 . . . . . . . $383 per tyre
Bridgestone RE55 265/35/18 . . . . . . . $418 per tyre
[ 17" tyres ]
Bridgestone RE55 235/45/17 . . . . . . . $348 per tyre
Bridgestone RE55 235/40/17 . . . . . . . $351 per tyre
Bridgestone RE55 255/40/17 . . . . . . . $375 per tyre
Comparison of tread pattern between older Bridgestone 540s and current Bridgestone RE55:
Enjoy B)
Cheers.
Mate I don't think you can really compare the Direzza DZ101's to the RE55's.
If we're comparing road tyres, I'd put the DZ101's against Bridgestone S03's, and I'd still prefer the bridgestones because they're damn good tyres!
But if we're talking R compound semi-slick race tyres, I prefer the RE55's over Yokohama's or any other brand.
oh derr im a retard i didnt realise the Re55s were like semi clicks. my bad sorry i thought they were one of the sports range tyres. jeez i feel like a retard haha
Please don't hide this away. I had terrible trouble finding the old thread last time I went looking.
It's cheaper for me to use your connections and ship them to sydney than it is to buy them here with a club discount from a club sponsor, let alone from any other shop up here.
It depends - but not ages.
Put it this way - I usually do say 10 track days a year and go a for a number of spirited drives but otherwise rarely use my car and I still go through 2 sets of these a year.
But without track days I'm guessing 10,000-15,000km's only.
I've had them for 1.5 track days and around 6,000 kms total road use.
I wouldn't expect them to last any more than 3,000 kms of road use plus a track day.
Oh and they're a very noisy, tramlining, irritating road tyre. If your car doesn't hit the track then I would spend a few more bucks and get a good road tyre (say ContiSport Contact 2s or Michelin Pilot Sports) that are simply awesome on the road and will last 30,000kms
thanks matt do you know how the compare against the dz101's
Sorry ot get off topic paul i don't know what rims size you hav but Dz101's in 225 50 16 and 235 or 245 35 r17 have been discontinued so this means the 16" version have dropped to $220 ish from $300 mark but if you go to a beaurepairs or anyone with big dunlop dealership you can get them for a good price :cheers:
but yest can't compare to re55's
  • 4 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
