Hey guys,
have a couple minor problems i need advice with or where to start looking, ive searched but cant find anything on each question..
This is for a R32 GTR
1) Brakes - They are hell spongy like they have air in them but they have been bled apparently. We replaced the master cylinder with a new one and then bled it again and its still spongy. Could it be the brake booster or?
2) Ticking sound at rear - When the key is in the On position, or when the car is started/running i can hear a 'click' under the car and the lights flicker at the same time as the click. When the car is first started it happens more often about 5 seconds apart, when its running it doesnt really happen while driving or i cant hear it anyway.
* When i take the 4wd fuse out there will be no clicking what soever and the lights wont flicker either, so im assuming its to do with the attessa system or ABS.
* i got underneath and i cant really tell but it sounds like its either near the diff or fuel tank (surely fuel pump wouldnt make lights flicker etc?)
3) Aircon - The aircon/vents only point to the window now, they used to move around like normal when the mode was changed, but now they only stay in the demister position and you cant hear the motor trying to move them.
Any help is appreciated guys :O Cheers
Edited by confuzion
https://www.sau.com.au/forums/topic/86184-couple-r32-issues/
Mine was the same when i first imported it, machined brake disks and new fluid helped the problem a bit, and some hard stopping helped the problem a bit more, i suspect that rust from the disks that accumulated during shipping embedded into the pads. im still not happy with it tho, and i doubt i will be till i get around to getting some new DBA rotors and some good quality pads. if it was me i would try new fluid (if you havent already), then machine the disks (if they seem warped), then check all the calipers are working correctly, if thats all ok better pads with more bite might improve the feel. if everythings working properly they should stop well.
I can also head a click/tick noise when i have it on the on pos every probably 5-10 seconds, i havent noticed it while the car is running tho, just when its on ON, but not running, i havent really listened either but im not concerned about it.
take to auto electrician/ buy new parts from a wrecker and fit them
they are just my suggestions i hope its of help
thanks dude, i have actually had the brakes serviced when it arrived as like yours there was rust on the discs, so they were all machined and bendix ultimates and metal kings where put on, plus now the master cylinder changed, so im thinking its either air which i doubt or booster at a guess..
cheers
89 shitter optional features... enjoy them :P
Hardly. These are quite common problems.
1. Check your brake lines. Make sure your using a quality DOT5.1 oil.
2. I did some investigating on this. Its a relay in the boot clicking on/off. Its for the 4WD or HICAS (I forget which -- I posted up some details you can search for if you really care).
3. Does the climate control display reflect the (supposed) change in position?
1. Very sure were using the 5.1DOT fluid i shall double check.
2. A friend suggested it sounded like a relay also. Is it anything to worry about/can it be fixed? Just looks kinda dodgy sitting there idling and my headlights flicker at the time of the click.
3. The climate control displays the change in position yes (eg floor or straight forward)
1. Well I would check your lines. Its not uncommon for them to perish over time. Also, how tightly secured is the master cylinder?
2. I find the interior lights dim momentarily: can't say I've noticed the headlight dimming too. Either way, if its just the relay its normal. I've often wondered if a better battery or one of those earthing kits would help.
3. No idea then. Have you tried the error codes on the climate control?
3. I have and it flashed the code 31 32 34 35 36 or whatever it is, which states that a 'connecter' is unplugged. I have pulled the whole freaken dash apart and traced everything i can and i cant find any connecter or wire unplugged. It will probably have to be a sparky's job :P
Thanks for replying dude ill check the lines etc B)
... which states that a 'connecter' is unplugged. I have pulled the whole freaken dash apart and traced everything i can and i cant find any connecter or wire unplugged.
There is a connector in the engine bay, basically immediately behind the coil ignitor module. It connects to a sensor that clamps around one of the heater pipes back there.
This one? (attached). Shes plugged in :) Ive checked all fuses in the engine bay and the inside fuses too :|
yeah thats what i mean, in diagnostic mode the unit flashes something like '31 32 34 35 36' which in the R32 service manual and also what a search brings up means a connecter seems to be unplugged..
grrr summer is coming up :)
:D
brakes. have you bled the abs as well?
there is a special sequence to bleed, can't remember it off hand, follow gtr workshop manual. if that fails get a pressure bleed done on system, this should force out any air hiding away.
ticking noise at rear. could be hicas or attessa. check Attessa resovoir in right hand rear guard (remove small interior trim), should be done with ignition on, and level should be between marks. normally when you start car, the attessa pump should prime the system so that there is adequate pressure that can be applied to clutch packs for 4wd system when it is required.
check power steering fluid levels, same fluid resovior used for front and rear steering racks -for R32s.
maybe fuel pump is on way out?? is fuel pressure ok?
ok brakes !
with the car off and me pumping the brakes, the first pump is squishy then every other pump is hard like it should be
with the car ON and idling with me pumping every pump i hear a PSSH and obviously its squishy. It sounds like its from inside or in/outside the firewall so im assuming the booster is leaking?
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
