  • Replies 50
It was anything but that actually
there was some of that around, but some of the talent getting around was insane
I wouldn't go again though for a few reasons, such as asshat organizers (Right Mick?)
Edited by Bluprint
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1591060
there was this one chick that he thought was a girl.....but lets just say she had an awefully big adams apple for a chick, It was a good disguise though Beau!
I almost fell off my chair after reading that, cos I know what REALLY happened to Mick! :lol:
(tha bastard)
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1591300
It was alright, played to much on the 70's thing and didnt give the great dj line up enough time, but after putting away a bourbon or 10 i didnt seem to care to much. Id go again. next one in either may or march (may me thinks) next yr. Hopefully they will have different MC's at the next one, that big brother guy was a dick
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1593850
Yeah he was a bit of a cockster
looks like he was high as a kite (probably was).... it was kinda amusing watching him try to navigate across the dance floor (which was largely empty at the time)
I thought Cabin Crew were alright
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1594229
I would say shit all shit, the line up sucked the first DJ couldnt mix piss and crap in a toilet if he was sitting on it, the band may as well have gone home. The last DJ was good or maybe i had just drank my share of crap drinks, the chicks were mostly hot but with the same old pathatic attiude oh you dont look rich or wog to me. Oh the food was found in some tip somewhere then served to us in old style chinese boxs but none of the food was anywhere near chinese.
All in all i dont think ill ever be going again and there lucky i dont right an abusive email wanting my money back
Oh the venue was great but thats it
Edited by race_snooze
https://www.sau.com.au/forums/topic/86279-dd-ball/page/2/#findComment-1594260
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
