im about to put my car on the dyno. right now my spark plugs are gapped at .8, but i fixed my coils (sanded the inside of them) over 2 months ago and havent gotten one single misfire since. i want to know if i can re-gap them to 1.1 to allow for a bigger spark. i'll be running 14psi on the day.
also, what are some things i can look at before putting it on the dyno?
https://www.sau.com.au/forums/topic/86302-tips-for-dyno-runs/
do you run 14psi on the street? if your on the stock turbo its the sure fire way of killing it, the heat generated by it will kill the exhaust wheel and i doubt it will make any more power if none at all from 12pis to 14psi but there will be lots more heat. even 12psi is risky for the exhaust wheel.
with stock ecu id say 160rwkw ish ? without piggyback or aftermarket ecu then yeah about there. 12psi and 14psi will do stock boost cut and your power will go out the window if you still have the stock ecu, it detects too much airflow and cuts the timing
A larger rolling diameter tyre will give a smaller power reading.....fact and proven.
when people upgrade wheel sizes, they generaly also reduce the profile so that the rolling diameter is still the same - wouldn't think a tyre company would recommend incresing the overall diameter
but even if the overall diameter is the same, then the 19s are probably going to weight a bit more than the stock 16s due to there needing to be more material to make up the larger rim. This would increase rotating mass and thus reduce power transmission through the wheels...
well ill get 3 runs anyway, ill do one on 10, one on 12 and another on 14 and see how i go from there.
how much power should i be expecting?
ive got a 3" turbo back, k&n pod, fmic.
well 2 weeks ago I dyno'ed my car..
I got 158rwkw. Was quite surpised.
This is stock r33, stock everything. POD and HKS cat back.
On the day stantaic had his auto GTT, that only did 156.0, also a R33 S2 (links's car) did 156.5. Both of them had cat backs and had stock air filter.
As has been said a number of times - dynos are a tuning tool.
I don't understand why you're asking what 'needs' to be done prior to a dyno run... as long as the car is running fine, put in fuel... put on dyno.
I have to ask - why run a higher boost than you run on the street? It won't give you a representative figure of what the car is running in street trim.
If you want a dyno sheet to say that the car makes 4000gigawatts, then just photochop it. Dynos are useful if you use the same dyno, prior to mods, then post mods, on a similar temperature / pressure day, to determine a relative increase of your mods.
its not that i want it to show more kw than it is on the street, im just asking questions on what to expect, and you guys have answered all of my queries.. are there any other things to look at besides fuel filter, spark plugs etc?
i just want a clean run.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
