That sucks Tommy. It's your tyres though. I personally love the rain and was having a great time yesterday with the wet roads. My front torque split guage peaked at 42.1% - that's the highest I've ever seen it go! I must've been spinning all four for it to resort to that.
I've got 16" protenza's III on stock rims.. they're good 90% of the time in the wet... however give them any stick in 2nd you'll be having fun up the road.. also going around an off camber roundabout in 2nd.. they decided to let go.. combine with a LSD and they both started spinning.. alright though.. just back off and it's snaps back..
personally I need some wider tyres.. but I think the protenza's are alright..
I just don't understand people who skimp on tyres :)
They're the ONLY thing sticking your ass to the asphalt and saving your ass... I'd even say that it's the most important thing on your car.... and yet there are still people riding around on Falken Ziex tyres :) I think the solid plastic tyres on my model cars give more grip than those useless things :(
And if you think that "oh but it won't be as much fun because I won't be able to get the ass out with sticky tyres, that's absolute craaaaaaap. Of course you can still induce power oversteer. But in any case, once you realise just how much HARDER you can launch, and how much FASTER you can corner with sticky tyres, you'll soon forget about stupid sideways driving ;)
This is true.
I admit i don't have great tyres but i drive like a granny in the wet. I would rather drift in the dry(if i had the power).
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
