Hey guys,
I got a prob with my front passenger rim on my 33. i thought the tyre somewhere had a leak as the tyre leaks air over about a month b4 i need to constantly reinflate it, so im always topping it up. i got it all checked out thinking it was the rubber, but they found a hairline crack in the actual rim.
I have 18" ROH Drift R's on the car, and i dont really want to replace that 1 rim which will prob cost 500 bucks, but it looks like i have no choice, it must be fixed or it will always continue to leak.
Is it possible to like get a tube put in just that wheel to fix it, as these type of wheels are tubeless..if thats the case id much rather pay 40 bucks than 500.
any advice would be appreciated
https://www.sau.com.au/forums/topic/86600-problem-with-rim/
you can get it tubed at your local tyre place should be no dramas however i would be concerned of the safety of the rim itself if its cracked.
it could be unsafe and expand more or crack more at high speeds, that would be fatal, especially on the front
https://www.sau.com.au/forums/topic/86600-problem-with-rim/#findComment-1565224
um iam pretty shore they dont make tubes for 16-17-18s coz they low profile, could be wrong about 16s but others iam shore off, just get some reall good glue n tank the tyre look 4 where air is comeing out n GLUE it, but i would fix or get new 1 if u wont i can get u these rim most likly.
https://www.sau.com.au/forums/topic/86600-problem-with-rim/#findComment-1569968
i would advise against the tube idea even if you can find one for your wheel as they are not the safest things going around (excuse the punt)
as someone suggested best thing is to get it repaired by wheel repairers.
https://www.sau.com.au/forums/topic/86600-problem-with-rim/#findComment-1570307
I got the wheel checked out at an ally repairer, the wheel is f***ed. the crack is too close to where the spoke meets the inner part of the rim so the only option is a new rim. but the rim is $280 so its not too bad..i was expecting them to be around 400-500 per rim.
And yes im still getting the 34. had it checked out and all looks good.
https://www.sau.com.au/forums/topic/86600-problem-with-rim/#findComment-1576025
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
