Hi everyone, quick question about my climate control unit. When it's on 18C (manual setting) it blows cold air, all good, but when i turn the dial to raise the temp it starts blowing hot air i.e. on 19C and above it's like the heater is on. So I can be freezing or cooking, no in between. I'm guessing it's stuffed, does anyone elses do this? Is it likely to be the unit in the dash thats all bad (something electrical perhaps) or could it be anything else before I spend the $350 I was quoted for another dash unit?
Thanks
Edited by deano_33
https://www.sau.com.au/forums/topic/86667-climate-control-problem/
Check the little pipe that sucks air in from the dash to check the temp. On the '33 its a little circle grille near the ashtray (from memory). Not sure where it is on the stag yet. But make sure its not blocked or bent etc as it will misread temperatures.
Does that make sense?
Update: Got another climate control unit from wreckers ($350), didn't fit, different plugs on the back, same number of pins but just slightly different so don't fit. I guess the S1 and S2 stageas are different there. Wrecker is going to try to find one from a S2, don't fancy my chances though. Might have to try Nissan, can't imagine what it would cost......
Had a look at the temp sensor (to the left of the steering column?), seems OK but I don't think that would be the problem seeing as the problem is the same in auto or manual mode?
Hmm, might have to live with it for a while.
Edited by deano_33
My Stagea does exactly the same thing. I just assumed that it might have been sensing that the cabin temp was already less than 19 degrees, so it actually started blowing in hot air to bring it up to that temperature. 19 degrees inside a car with no sun shining in through the windows would actually be quite cool, wouldn't it? But now that I think of it, the times that I have tried it and it has done this have actually been at night. I'll try it again tomorrow, when the outside temp is 36 degrees with 110% humidity and see what happens. Hmmmmmmm
I think the problem could be the thermistor (thermally sensitive resistor) behind the cluster surround.
Try to replace this part first and see how that goes(few dollars i assume), because if it is old it could be sensing mega wrong resistances... and also being the "control" unit of the whole climate sensing idea..
Also, it may be dusty, so give it a good blow to get dust off (insulation)
Okay Alexcim I'll have a look, thanks for going to the effort of marking the pic!
Auto/torque converter has pooed itself though in the meantime - feels like a slipping clutch in a manual and can hear metal on metal sound, not good. Getting this attended to atm.
Might be a stupid question, but have you run the diags on the climate control to see what error it comes up with ?
J
No, not a stupid question. You get it into diag mode by holding down the off button and turning the car on right? I tried it and lots of crap comes up, how do you interpret what displays on the screen?
Cool,
Have a look at page 31 of this doc, it's probably the same as the R33 (fingers crossed).
J
skyline_book.pdf
I thought that if the A/C is in Maunal, the Compressor doesn't come on unless you push the 'A/C' button.
If that is the case, if you select a temp that is lower than the outside, outside air will blow in. If you select a temp warmer than outside, the air will be diverted through the heater.
Does this sound correct?
I think mine assumes it's always hot outside, I have to set it to around 25 or 26 degrees to keep myself warm...
Oh, and when adjusting stuff, how do you press the "Hot" button when the Stagea has a dial instead? Do you just turn it up to a warmer temp?
Hey, isn't there a button you can press so that it displays outside temperature?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
