Need to get rid of this parts-
-complete door -$330*2
-rear bar $90
-boot lid with spoiler $100
-starter motor $80
-factory computer auto and manual $100 each
-tail light $100 for both
-feul tank $100
-automatic gear box $100
-Hks air filter or k&n, for $30
-standard injector $130
-brake booster $50
this parts need to go and willing to send to other state at buyer expense.
Din 0415642296 [email protected]
Edited by dinzlr
https://www.sau.com.au/forums/topic/86874-r32-gtst-parts/
  • 7 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
