I can't seem to get hold of K-Style, they won't reply to my emails :)
Maybe it's because im in the UK and they don't wan to export :(
yeh same here. They havnt replied to any of my email either. Guess they dont want business...or they are computer illiterate and cant use email :rolleyes:
boostED82, how much boost you r running? I'm running similar setup but without power FC, xtreme 2500 clutch kit, hd coilovers and sard fpreg (what's this anyway?)....with 1.05 bar of boost, only 244 rwhp.....
Hey mate, 1.2bar so 17psi. That was on a 4wd roller dyno (non-shootout) shootout is 289rwhp. Apparently this is a little low as others in WA have got closer to 300rwhp with the same setup. Still, it's enough power for the road in my opinion.
fpreg = fuel pressure regulator
Well I finally got my Uras on with my home paint job :(
This is the car when I first bought it:
Funnily enough it was only 10 mins from my house. Just noticed how nice the paint is in this pic compared to the present shots.
This is the present shot with Uras attached:
Enjoy it!
Come on Dave there are plenty of sweet Ceffie's for sale!!! :P
Just bite the bullet and join the COOL crowd & own a Cefiro :P
THEN.....we can group buy WSX kits!!!
Oh oh oh, lots of goodies to be bought tomoz!
Coilovers
Coilpacks
FMIC
5 stud convertion kit
BOV
Wheels
Seats
Gauges
Turbo..... on the way :(
Oh the wallet is gonna hurt by Saturday arvo :)
Bring on more POWER!!!!
Booyah
Ando
Just bite the bullet and join the COOL crowd & own a Cefiro :)
ha ha ha! only one thing holding me back at this point man.... $ :P
saw a mad gold one in hornsby the other day though! :D
Sounds like a good shopping list as well :)
ha ha ha! only one thing holding me back at this point man.... $ :)
saw a mad gold one in hornsby the other day though! :P
Sounds like a good shopping list as well :P
Plus i'm really FUSSY... when i get one, i want it in white, immaculate condition and as close to stock as possible. Talk about a Dreamer ha ha ha!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
