Sk,
duno if you got my pm. I'm interested in getting everything besides the sway bars at this stage, please work out a price and send me payment instructions.
Cheers,
Dave
Dave has bought the last set of R32GTR front Bilsteins, if you have an R32GTR and are desparate I can arrange an alternative. There is extra cost (around $100) as they would have to be revalved to suite. There are still some sets of rears in stock at Bilstein. Consequenlty I will hold the Group Buy open as long as I can.
:thumbsup: cheers :)
  • Replies 239
Posted Images
Hi there sydneykid.. sorry to msg u here.. your pm box is full.. just checking whether you received my pm about springs/shocks for my r34 gt-4
cheers
PM sent
:D cheers :P
Hi there SK,
I have a few knocks from the front and back of my 32 GTR and can see a few worn bushes around.
Question is that if I replace:
Front and rear Camber Bush's
Caster Bush's
Cradle Bush's
Would this cover all the suspension related bush's or are there others?
Also I believe that the front camber kit is reduced to $183?
Thanks for your help!
Hi there SK,
Caster Bush's
Cradle Bush's
PM sent
:laugh: cheers :P
Good news, after much searching I have been able to find 10 sets of R32GTR front Bilsteins and they arrived today.
Update, 2 sets have already sold, so don't delay.
:pirate: cheers :kiss:
Thanks SK
Finally got my kit installed, I went with a stiffer spring and some adjustable rear upper arms that were'nt in the kit, but essentially the full GB. You get used to driving on the street with saggy suspension but when you get it on the track it really focuses you on the problem. The handling is now sharp and predictable, this street package plus my extras delievers as advertised... good scope for adjustment for MC days etc yet compliant enough for the street. The ride height advice was spot on too. Money well spent, also thanks to W.A. Suspensions for the excellent advice and install
SK,
I'm a definite... Put me down for the full monty please.
Just got to find a pair of standard rear upper control arms (Anyone???) or a pair of adjustable rear track bars to compliment the adjustable rear upper control arms I already have... anyone know where to source these?
Regards,
Shuey R32
SK,
If I wanted a slightly harder spring for the rear end of my R what would be the least painful way of getting it done & would the shocks need revalving? All the reast of the suspension kit is from the parts list on this thread.
hi sk i would like to order 4 bilsteins and 2 sets of bump stops for r32gtr i have worked out the cost to be $1195 is this correct?. if available can you pm me so i can transfer money , thanks loren.
SK,
Whiltein only make the one rear spring rate, you would have to go to a coil over kit.
Revalving depends an how much higher spring rate you want to use.
We should take this to a PM, rather than clog up a Group Buy thread.
PM sent.
:thumbsup: cheers :laugh:
Sorry, this Group Buy is closed for shocks as there is no more stock of rear R32GTR Bilsteins. I will re-open it for shocks when the next shipment is confirmed.
The other items (springs, bushes and stabilsier bars) are still available however.
:( Merry Xmas to all at SAU :)
PM sent.
:( cheers :ninja:
OK, but your in box is full and/or disabled...
Gary, I have finally got enough money to get the rest of the stuff i need. If i was to order bushes/stabilizer bars now when could i expect them to be delivered with all the christmas stuff going on? Thanks
Bushes are usually in stock at Whiteline
Stabiliser bars take 4-5 working days to make as Whiteline do not keep stock
Delivery is via Toll priority and usually takes 1-2 working days to anywhere in Australia.
So, no chance before Xmas, closed between Xmas and New Year. My guess would be 5th January, but that's just a guess.
:P cheers ;)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
