well you'll notice you've only got indicator holes in the east bear covers, to make it look semi coupe-like. Unfortunately sedan tail lights incorporate reverse lights. as a result east bear supplies the covers with a little reverse light to mount into your rear bumper (which looks ugly as sin) see the white thing on the bottom of your rear bumper? Unless you're happy running around with those. Dunno if they'll pass compliance though.
inark here you go
http://www.e-aero.jp/aeroparts/skyline/r-32/tail-kit.html
If you’re worried about damaging them because we all know you’re going to crash the car !!
I will swap you my stock tail lights plus cash for them
yeah bound to crash... will just try my hardest to make sure its side on :)
looks good mate. will be nice to have a car just to slide around in.
can i ask is this coming in as a 15yo car, SEVS car, or race/rally car? I ask as i am about to buy another car too, just looking at options. :)
15 year old import. came up at one of our suppliers a while back, the buyer backed out because he thought it was too far from being daily drivable (stripped interior, bolted harness mounts etc) and I knew narky nuts wanted a car so offered it to him :D
narkeh sold it to jairus who blew up the engine. I think its being sold again now though without the engine or something.
Seeing as Benny's left chasers, god knows what's gonna happen to it.
Looks good inark, I have just bought one in the same colour but auto with complete service history and logbooks :D
Im looking at a possible 5 speed conversion down the line but for now I have stuck some 32 GTR wheels on it which have made a huge difference to its overall look.
Makes a hell of a daily driver!
Richard don't you have enough cars mate?
Nice sig haha
hehe, nah I am down to two measly cars now. Plus I really want a car just for track work. something cheap cheap. :D
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
