I enquired about the Free Trade Agreement with customs officers at Clyde, they clarified that it only applies to goods manufactured in the USA, & there has been some confusion over this point.
example A: goods mfg in USA, purchased from USA, no import duty
example B: goods mfg in Canada, purchased from USA, 15% import duty
example C: goods mfg in USA, purchased from Asia, 15% import duty
Also there are concessions for certain vehicle parts, but i didn't get the lowdown on that.
so... buyer beware !
Never had a parcel opened by Customs from the USA since January, if it is post marked "from the USA" they seem to let it through. If the value is high enough they slap some GST on it, but never had any duty applied.
The definitions of "made in", "manufactured in", "product of" etc are just as blurred as in Australia. I think it is just too hard for them.
:wub: cheers :wub:
Edited by Sydneykid
The 15% duty is long gone from anywhere , its now 10% from countries other than USA ( since jan 1-05 ) however bigdatto is correct but in practice what SK said goes , no-one will open a parcel from USA but dont forget the 10% GST is payable always .
I only mentioned this because they did open the parcel (in front of me) & said "WTF is this ?? (to use the parlance of our times). If I had let the parcel continue to the post office I'm sure it would have remained sealed. But xmas had come early & I couldn't wait !!
;) cheers  :)
dude i got ripped off by custums they charged me more than my goods were worth, they had what i paid then put what they thought they were worth, WTF i got it shipped through UPS, which i thought weren't too good but who do you get your stuff through?
not always...
You may not pay but its payable , regardless where you buy localy or o/s .
You must also pay gst on the cost of freight .
link to his ebay account/username/goods listing would be much apprecited
Because I am a nice person:
http://search.ebay.com/_W0QQfgtpZ1QQfrppZ25QQsassZmybasquie
i think bigdatto has done that on pg 1,
i tried emailing the guy about the HKS TO4R but no response yet.
Yeah, I also emailed him an no response yet.
i got a response from him yesterday..... doesnt stock internal gated T3 turbos..... :D
but finding out about external stuff shortly.
i think he'll find he's way to this post shortly.. coz he ask where i found out about his details.
  • 3 weeks later...
what about things bought from asia? what taxes apply there??
Depends on the item, but standard GST/import duties apply. This may change in the near future if the proposed free trade agreements with some of our Asian neighbours go ahead.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
