Mc Motorsport 'come & Try' Day - 9th Oct
MC Motorsport individual ‘Come and Try’ Day
Date – Sunday 9th October
Time – AM or PM session (8am – 12pm or 1pm – 5pm)
Where – AHG Driver Training Centre, 46 Grogan Rd Perth International Airport
Cost - $70
AHG has 8 places available for individuals to come and try MC Motorsport competition. This is to be held on the same day as normal team competition (ie the one SAUWA competes in) and individuals will be mentored by Team Captains –so don’t worry someone will be there to tell you what to do! ;)
MC Motorsport involves driving on a skidpan (rectangular shaped bitumen pad) around witches hats which are laid out to form an obstacle course. You are timed from start to finish with penalties for hitting cones or going the wrong direction.
I have attached the days challenges which are 4, 7, 16 - you will need to memorise these. :)
DRIVER REQUIREMENTS
- Helmets are compulsory – Approved Safety (AS 1698, Snell SA90, BS6658-85)
- Long sleeves and pants required. Covering neck to ankles to wrist. Non –flammable no nylon or synthetic clothing permitted.
- Fully enclosed footwear
- Sign indemnity form on the day
VEHICLE REQUIREMENTS
- Car to be registered, roadworthy, no safety defects (no yellow stickers) and no fluid leaks
- Seatbelt or harnesses fitted
- Battery to be securely fixed
- All loose items to be removed from inside the vehicle
- Tyres to be road legal – no slicks
- Efficient brakes
- Vehicles must complete all tests using the same tyres fitted during the vehicles first run of the first test. Wheels and tyres may only be changed due to damage - which must be inspected by the scrutineer. Wheels and tyres can be rotated front to back.
- Vehicles must have two front seats. Rear seats can be removed for harness mounting.
- Vehicles must have factory dash.
- Cars must compete with windows either fully up or fully down
If you are interested please contact ASAP
John Clark from AHG
[email protected]
Ph. 1300 888 987
3_amp_4.pdf
7_amp_8.pdf
15_amp_16.pdf
https://www.sau.com.au/forums/topic/87721-mc-motorsport-come-try-day-9th-oct/
IF THERE IS STILL A SPOT AVAILABLE I WILL DEFINETLY BE KEEN AS IM NOT WORKING THAT WEEKEND AND I AM REALY KEEN TO THRASH THE SKYLINE.
Let us know if there is still a spot available and ill be there. Cheers Matt
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
