I have finished the engineering on the R33GTR and R33GTS4 suspension kits. There are quite a few differences in settings and parts selection, particularly shock absorber valving which needed a large number of changes. I have also included the often requested Dust Cover and Bump Stop kit, you only need it if you have to replace your broken, lost or worn out standard parts.
The supply of R33GTR Bilsteins is also quite limited, so don't hesitate too long with taking up the Group Buy as they will all be gone. The next shipment is not due for at least 5 months.
Please PM me with your order and post up any questions you may have on here. As it may answer other peoples questions at the same time. Fitting and alignment can be done at the following locations
Heasmans Sydenham NSW
East Coat Suspension Kirrawee NSW
St George Steering Punchbowl NSW
Centeline Thomastown Vic
Traction Tyre & Suspension Rowville Vic
Discount Tyres Service Belconnen Act
Motsons Qld
More fitting stations will be posted as they come to hand. Please note that the above fitting locations are workshops that I have used in the past, so I know that they can do the necessary work to the right standard and have the right equipment. No special prices or discounts apply, you can negotiate fitting cost and times directly. A full kit will take at least a whole day as the bushes in particular can be time consuming to fit.
:) cheers :D
PS; Shocks and springs are currently in stock, bushes and stabiliser bars are made to order. So delivery is ~10 days from time of order, all items are shipped via Toll Priority using their Off Peak service. Consignment note numbers will be provided at the time of shipping, so your order can be tracked via Toll.
Payment should be made in full to the bank account details at the bottom of the price list, the receipt number for internet banking is acceptable or a copy of the deposit slip for over the counter banking. Send them to me via PM.
Edited by Sydneykid
  • Replies 105
Posted Images
For the guys that are ordering the Bump Stop and Dust cover kit. You will have to trim the bump stops to suite the correct height that you are going to have your car set at. The dust cover clips ove the end of the bump stop stop so you have to trim the other end with a knife, be careful it is easy to slip and cut yourself.
This is a picture of what the bump stop and dust cover assembled would look like at higher than standard height;
This is how much much to trim off the bump stop, shown next to a standard Skyline bump stop. The orange line is for standard height, the red line is for ~350 mm centre of wheel to guard and the yellow line is for ~330 mm centre of wheel to guard.
Note that standard height is 2 circlip grooves up from the standard circlip groove, ~350 mm is the standard circlip groove and 330 mm is 2/3 circlip grooves down from the standard groove. You can pick the standard groove as it has a yellow stripe accros it. Plus the circlip should be in that groove when you get the shocks.
If you are using the standard bump stops they also have to be trimmed if you are going lower than standard height. Not that you have to trim the thick part of the standard bump stop, not just cut off the little lump on the bottom. You will need a hack saw as the rubber is very tough. The red line (no trimming) is for standard height, the yellow line is for ~350 mm centre of wheel to guard and the orange line is for ~330 mm centre of wheel to guard.
Hope that was of some help, if you have any questions please post them up here as it may answer other peoples queries as well
:D cheers ;)
Edited by Sydneykid
Hi guys, there are only 2 sets of R33GTR Bilsteins left. As soon as they are sold Jamex will be closing the Group Buy on the R33GTR kit. We have no word from Germany as to when they will be making the next production run of R33GTR Bilsteins.
So if you are thinking about joining in, don't wait too long.
:) Cheers :)
Edited by Sydneykid
Apexi suspension still making me cry :) (hint)
So looking forward to real suspension and not losing fillings on the "fine" melbourne roads.
:)cheers:)
:)cheers:)
Don't strees Geoff, your Bislteins are safe and warm in my office. Just waiting on front springs, I'll give you an ETA later today.
;) cheers :)
Update: I was advised of shipment Tuesday and Delivery occured Wednesday. No sweat on the delay as I already knew some items needed to be manufactured. A couple of items still to come but I now have the important items to smooth out my ride.
How am I feeling? Ecstatic!! What a great shock/spring setup. Massive increase in front grip on bumpy corners.
Thanks SK.
  • 3 weeks later...
Quick update on stock, there are 4 sets of Bilsteins left for this model. When they are gone the Group Buy will have to finish. So don't hesitate too long or you will miss out.
:) cheers :)
  • 4 weeks later...
  • 2 months later...
  • 1 month later...
Hey SK,
You still have any of these? I am just after the stabilizer bars and subframe alignment atm (I have nice shocks / springs atm).
Thanks.
Christian
  • 3 months later...
Hey SK, can I order some sway bars from you?
I don't have any, but I can organise some from Jamex on the Group Buy for you.
PM sent.
:D cheers :(
  • 1 month later...
There area limited number of rear Bilsteins in stock, so move quickly or you will miss out. No production planned at Bilstein Germany until after Xmas.
:dry: cheers :D
:nuke: cheers :D
SK,
What coil overs could you recommend with this package. I've been told PSS9 are a good option. Have you done a track setup yet?
SK,
PSS9's are OK for lots of track use and a little road use, in my opinion more suited to road use than 90% of the Jap coil over kits.
I have done a few height adjustable circuit kits and a couple of drag kits for guys, using revalved (non adjustable) Bilsteins. The guys were much happier knowing the Bilsteins had a wide window and didn't need them to be experts in choosing shock settings. PM me for details.
:no: Cheers :D
  • 3 weeks later...
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
