Hi Gents,
Now that I have my shiney new Splitfire Coil Packs (Big Thanks to the guys at Kudos Motorsports) I need to fit them.
My current plugs are gapped at about 0.7-0.8mm.
What should I gap them too?
Would 1.0 - 1.1 be about right?
BASS OUT
https://www.sau.com.au/forums/topic/87888-plug-gaps-and-splitfires/
If its any interest to anyone, i've tested my std gtst old coils and the new splitfires, and aside from the primary winding resistance being .6 ohms against the stock ones .7 ohms, the secondary coil current is the same as the stock old ones(1.4ma). Also the spark gap they will jump is also the same.......(18mm)
This was using a set frequency coil tester, around 50 - 60 hz odd...... for 9000 rpm the freq would be 75 hz, so pretty close. stock coil might drop off abit at high freq, but i dont think its as much as they seem to indicate.
Anyone else done testing to argue otherwise ?
Gary
Gary
I don't even know what you're on about, how can I argue? :lol:
They only reason they "seem" much better is a lot of people buy those as opposed to ones off Nissan which probably is more expensive.
I dont think they are any different to stockers... its just that they are a cheaper brand new alternative
A Brand new coil pack is going to be better than one that is 5/10/15 years old
Yeah that was my asumption too, there just a blue version of a new coil basically...... there are minor diferences in the primary resistance, and also the core seems to be two E cores instead of all joined together. (ie the metal former is not joined on the sides)
I assumed this when buying them, but since there new and cheaper than nissan, there the ones to get.
I would think all the guys who report more power have old coils starting to break down internally , and worst case externally arcing onto the coil brackets.
Only way i'd believe these are better is run a car on brand new nissan ones till it was blowing the spark out at a certain gap, then swap these in.... but i doubt there would be any gain on new coils.
For interests sake i also tested the secondary current of some other coils .
gtst - 1.4ma
bosch mec 718 2.1ma
S4 rx7 trailing 2.9 ma !
Gary
Thats exactly what ive been thinking for along time ;)
my coils started arcing to the brackets (at least three of them) and as has been mentioned i bought the splitfires because they were cheaper than nissan ones. they look exactly the same, and i can tell you that there was definetly NO power increase when compared to my stock coils when they were working properly ;)
and talking gaps, with my splitfires i have run both coppers and iridiums with the standard 1.1 gap with no problem, but only at 10psi.
Wow I thought we were gettin extra juice outta these Splitfires.... Ripped off!! Just like thier friggin spark plugs..
well talking plugs, i swapped old (40,000kms 2.5year) iridium ix plugs which looked fine for new coppers, no difference. i only changed them because they were old...
i believe the standard coils in conjunction with being old somehow get damaged inside after being exposed to a lot of heat.
mine started arcing all of a sudden, within days after i went to a skidpan day(refer to picture ;) ), lots of sustained high revs, and it was a very hot day
I found a 10psi 1.1 mm gap was fine on irudiums
but
at 14psi it was blowing out spark.... If i reduce the gap to 0.8 then i get a small flat spot where there is too much fuel and its drowning the spark bsiclly.... So im gonna toss out the split fires and run after market coil packs and spark plug leads....
Should reduce the heat issues these things have also....
$600 for a set of split fires.....
vs.
$400 for a set of 3 double packs from bosch and $100 on a set of leads from autobarn....
Much the same price but i know which will do a better job....
Remember this one basic rule....
If you want more power you need...
1. More fuel (040 fuel pump and bigger injectors and maby a fpr)
2. More air (turn up the boost)
3. More ignightion (bigger plug gaps and more power for the spark)
If you dont increase each evenlly you will have trouble....
i got 3rwkw increase on back to back dyno runs just by changing to the splitfire coils, which im not claiming is reason to go out and buy em! my std ones were getting temperamental.
Plug gap had to remain at 0.7mm otherwise id get missfires at 1.2bar.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
