  • Replies 288
come on Marko....
when is your car going for a tune???? :)
Im dying to get to PI with you blitz and snowman....
ben,
the car was tuned earlier this week or should i say 'touched up' by crd as the only thing that required adjustment was the afr - it was a little rich after the bottom end reco...
jim has tuned it at a lower boost which has given me 325awkw - he wants me to cover another 1500km (total of 3000km) before he performs the high boost tune (for safety sake) as the engine still feels tight on the dyno
the car feels great :P
Marko.
Hey guys, just got a quick question
Quickest time last night was 11.9 @ 114.5 mph.
That mph seems a bit low. I ran a 118 previously. Anyone have any ideas? I think i actually dropped (accidentally) the boost level to 1.2 bar or lower for this run.
It sounded like you missed third on that run tommy...which is why I got a shock when I saw the 11 come up.
no graph of the latest tune, just a general seat of the pants feel, and a quarter mile run.
Power feels smoother. Has more punch up top (too lean on CRD's tune) and more punch down low (too lean to spool the garretts).
Different tuning philosophy between the workshops.
The way it is setup now, it feels a lot more driveable
Well i gained 30hp after Bel's tune ?
I will say no more. LOL
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
