I'm pretty sure the competitor gates open at 5pm, racing begins at 6pm. I'll be down in a couple of weeks when the car is back together, it'll be my first time at the plex to drive as well :) good luck with it!
Don't you bust up your car before MC Jarrad!
btw - how many hp is your car now?
lol i hope i dont break anything either :lol: cant wait till next mc! B)
makin about 250rwhp now, changed dump/front pipe and some other stuff. Should go much better with the new wheels but
Cool. That wouldn't be the mc tuning arvo would it (30th)? I'm taking my car woohoo! I'm planning on taking my car to the plex on the 28th, hoping all goes to plan with the car.
I hear it's difficult to figure out how to race who you want though, because they constantly change the lanes n stuff....
No - its the MC competition on the 9th of Oct.
