What colour is your r33
105 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I went for a cruise last night down to chaple street and noticed something ive noticed alot before, it looks like most r33s are white! Theres heaps of them, i have one too so i was just curious to see via the outcome of the poll in percentage terms if most of them really are white, or its just my imagination? :blink:
https://www.sau.com.au/forums/topic/88084-what-colours-your-r33/
pffft sif, super clear red II which would be burgandy/maroon, and proly the only one to come from the factory with pearlescent paint? is way faster than any black one :D
although black is a stealth color, bitch hard to keep clean but.
Not really, there were plenty of factory pearl red/burgundy colours from various car manufacturers. I chose the '97 Ford Mustang factory pearl red colour :)
thanks mate
its official. best color on any R33 that ive seen. too good....you have great taste....i am mustang crazy....also a massive ford fan, and your mates XA is an animal!
i know some people that would cream over that.
thanks for the pics
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
