hey guys im in need of some new rotors mine are stuffed so i was looking at these ones on ebay i no its ebay the king of dodgey stuff but they seem ok! i got a quote from the guy and he said for slotted rotors it will be 550 posted is this ok and how are the quality of these rotors?
link Attached
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...ADME:L:RTQ:AU:1
https://www.sau.com.au/forums/topic/88113-slotted-rotors-r32/
i was just going to get them with this guy cause they were reasonably cheap and i dont no if he has the standards
are these the rda ones i wasnt too sure doesnt say..?
Edited by gt-t_r34
From Repco I picked up 2 DBA908's (rears) and 2 DBA4926's (slotted fronts) for $260pr and $363pr respectively. Worth looking into. The fronts were a bit cheaper than retail but you should be able to grab a pair for just over $400.
edit: stupid brain, can't do maths
Edited by cowie165
yerh i sent him a email bout gettin all 4
ill ring rda tomorrow ill probly end up getting slotted fronts and standard rear... i mite have to get new pads too because the warped rotors will have stuffed them yerh??
you have to get the old pad, and put it on concrete surface with pad surface down, then stand on it and rub it
this gets rid of any grooves cut into the pad by uneven wear on the rotor
they usually say when you get new discs to get new pads aswell because if you don't rough up the pad surface, it will cut the same grooves into the disc surface
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
