i have a r33 with some basic mods pod, fmic, t3/t4 hiflow turbo, 3'' turbo back ex, safc, hks cam gears.. and before i took it in to get the safc and cam gears fited and tuned (also an intercooler pipe leak fixed) the car ran smooth all the way through the rev range, now ocasionly i have noticed towards the top end of the revs when nailing it, i get a flat spot (feels & sounds like when the revlimiter is activated) but its coming on sooner then reline, i was thinking maybe because i have stock fuel pump and injecters that with the tuning the car got it's struggling to suply the fuel at times at the top end when its reall goin hard.. any help would be apresh
https://www.sau.com.au/forums/topic/88167-flat-spot/
Be careful bloke. One of the quickest ways of killing an engine is to run it lean at full noise. If you think this is the problem get it to a dyno & check the AFR. Should be in the 11 to 12:1 range. Any more than this & you can easily kill your motor.
https://www.sau.com.au/forums/topic/88167-flat-spot/#findComment-1592858
yeah i only just got it tuned on the dyno, im gettin a wolf ecu within the next week or so, but i might up the fuel pump be i put that in to ensure im not starving it of fuel. will the stock injectors need replacing what hp are they good up to..
https://www.sau.com.au/forums/topic/88167-flat-spot/#findComment-1593556
IF you have the dyno sheet it should have the AFR graphed. This will tell you if it is a problem or not.
Not sure what the max hp on stock injectors is. Best not to run them at 100% anyway. If needed you can either go to a larger injector (still on standard pump) or run a bigger pump at higher pressure (ie new pump & regulator) or if you want to go the whole hog all three.
https://www.sau.com.au/forums/topic/88167-flat-spot/#findComment-1594997
You're fuel pump is on its way out mate. Get it replaced asap, shouldn't have to say how bad it is not to have any fuel going into your engine.
Re: Injectors, it depends on how your injectors are. See if you can borrow a consult or find some other way of seeing what duty cycle they're running. Ideally 85-90% is what you'd like to run although 100% is fine too - theres just no chance of adding more fuel if your car needed it.
https://www.sau.com.au/forums/topic/88167-flat-spot/#findComment-1595584
has anyone els had this problem?or does this sound familure to anyone, just wana get to the bottom of it, sure im gettin a new fuel pump (bosch 040) in 2 weeks then the wolf put in and tuned all up again.. but i just wana hear if this sounds familur to anyone
also new injectors can wait a few months so will all i need is a pump or do i need a regulator aswell? can someone explain it all, thanks again guys
https://www.sau.com.au/forums/topic/88167-flat-spot/#findComment-1606845
map sensor replaces the stock air flow meter and uses guesswork to work out how much air is coming into the system. airflow meter measures all the air coming into the system via its hotwire setup.
lots of people believe its a restriction but it wont be. its harder to tune with a map sensor and it wont be anywhere near as accurate or good compared to an airflow meter setup. do you have rb20 or 25?
https://www.sau.com.au/forums/topic/88167-flat-spot/#findComment-1607429
i got a rb25... i am goin with the wolf though as i got a good price and my tuner i take it to told me to go the wolf, and i heard nothin but really good coments about the tuner the ocasional cold start problem but can be sorted out easy enought, really more worries about this flat spot and fixing it
https://www.sau.com.au/forums/topic/88167-flat-spot/#findComment-1607452
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
