  • Replies 105
  • 3 weeks later...
Didn't end up getting a 33 .... got a schweet S15 200SX instead .... more power + much less weight = woohoo!
fyi not sure if anyone saw them (on the day) but I had 3 x R33s as my wedding cars on the 13th April this year .... they looked sweet as!
Check them out! (click here)
https://www.sau.com.au/forums/topic/882-sa-role-call/page/2/#findComment-37063
Hey guy's name's matt member or SVD club looking for other people to go driving with after september when I get my car on the road again Hr32. Also looking for a GTR intercooler hopefully 33 rather than a 32, any help would be good:)
https://www.sau.com.au/forums/topic/882-sa-role-call/page/2/#findComment-38271
  • 3 weeks later...
Guest Cob@lt60
Well, well, well,
there are some familiar names to me in here.. :)
Boosted32... saw you the other day drving up south rd.. I was in mums festiva though so dont blame you for not looking.. :D
Bugalugs.. how are ya bud? still cruizin ;)
Chris32.. I'll be ready for you cooler when your ready... (I hope)
Whatsisname.. I came on a cruise with you and joel and a couple others a while back..
Sinesweep.. hows things bro? you still got your vette?
Anyway.. enough reminissing.. :(
https://www.sau.com.au/forums/topic/882-sa-role-call/page/2/#findComment-58767
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
