  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sony 5.1 Amp/Reciever (can't remeber the model 645 or summit)
Pioneer 515 DVD (yes it's old but does the job)
Panasonic 80cm TV
Sony CS-1 SuperLite LCD Projector
Yamaha active sub woofer at the front
US Audio passive sub between the surrounds at the rear
2x Jensen front speakers
Jamo centre speaker
2x US Audio surround speakers
I used to use mine all the time, my last place had a nice white wall to project onto. It's like a personal cinema.
New place has *gag* yellow walls in the living room and I only have a crappy old 120cm screen, it's just not the same.
I'm thinking of selling mine actually seeing as I never use it now :(
Hitachi 5.1 AMP supports both DTS / DOLBY DIGITAL
Hitachi DVD supports both DTS / DOLBY DIGITAL
Panasonic Tau 80cm Flat Screen TV [farkin expen$ive]
Pioneer Linear Series Speakers [2 x 200watt fronts each with 2 x 10inch subs] [2 x 160watt surrounds + 1 x 160 watt centre].
power quotes are maximum outputs.
and, no i dont need a seperate subwoofer :uh-huh:
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
