  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sony 5.1 Amp/Reciever (can't remeber the model 645 or summit)
Pioneer 515 DVD (yes it's old but does the job)
Panasonic 80cm TV
Sony CS-1 SuperLite LCD Projector
Yamaha active sub woofer at the front
US Audio passive sub between the surrounds at the rear
2x Jensen front speakers
Jamo centre speaker
2x US Audio surround speakers
I used to use mine all the time, my last place had a nice white wall to project onto. It's like a personal cinema.
New place has *gag* yellow walls in the living room and I only have a crappy old 120cm screen, it's just not the same.
I'm thinking of selling mine actually seeing as I never use it now :(
Hitachi 5.1 AMP supports both DTS / DOLBY DIGITAL
Hitachi DVD supports both DTS / DOLBY DIGITAL
Panasonic Tau 80cm Flat Screen TV [farkin expen$ive]
Pioneer Linear Series Speakers [2 x 200watt fronts each with 2 x 10inch subs] [2 x 160watt surrounds + 1 x 160 watt centre].
power quotes are maximum outputs.
and, no i dont need a seperate subwoofer :uh-huh:
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
