  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Dam we cant do that we would be getting rid of the huge DB of information that we have accumulated in this thread :P yeh proly a good idea Jimih but i wouldnt know how to without going through each and ever post and god knows im not gonna do that. Maybe we should make vspec a mod 4 a day so he can clean up his mess:P
Boostzor,
Hey, I resemble that remark. I didn't make all the mess, just most of it.
Skyzerr,
I agree with your guidlines and will attempt to follow them, but we do get incursions from the east, which will just treat it as there own Wasteland.
Pva,
Score, lady in the red dress, she didn't turn into a Mr Smith did she?
See'ya:burnout:
Thats still what I would consider a light tune. The exhaust is an absolute must, removing the boost restrictor for 14psi is easy, and suspension doesn't affect the car too much as the factory setup is probably as good for the drags.
Either way I think it is a very good time, hope more GTR owners get out there and show what they can do. I'm looking forward to when Gtrken pulls his out for a run.
See'ya
:burnout:
GTS-t VSPEC, my best time there was 14.106 @ 101Mph with 60ft of 2.2?? and reaction of around 0.6sec, i wanted to go faster, but dont we all.....
some guys in a old VK commonwhore was giving me shi# the other day about only doing a 14.10, they couldnt stop laughing, but either could i when they started their car up and the biggest cloud of black smoke emerged from their exhaust, and hes still yelling out the window giving me crap!!!! i bet he couldnt even see thru the smoke from their car..... :D
:lol:
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
