  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well im off. See everyone soon.
Ill be getting connected to the internet in about 2 months or so. After i get my loan approved. Dont wanna have to many expences to tell them about.. gives me more chance.
Enjoy the rest of your weekend everyone.. troy and i are off to PEARL JAM :) WHOHOOOO
doesnt take u guys long to close down a thread so i'll use this one instead - Thanks to everyone for there company today - im sorry i was bit (hmmm big under statement) tired and hungover.
Thanks to Joe for driving - managed to keep my baby in one piece - im impressed. Sneeza and the rest that got a little bingled hope to see your cars back looking shiny and new on the next cruise!
Thanks people for a great day - gotta go get the ret of my beauty sleep now.
Cheers
Lolls
Went really well unfortunately a bingle between
Hicks sneezer and Edwin i think it was..
Hicks come off lightly but sneezers car has front end, bonnet and associated damage.
And unfortunately Edwin, which im unsure what name he goes by on the site apparently wasnt too flash and had a mate bring a trailer....
I didnt actually see any of this we had already arrived before i heard the news
Apart from that it was good....Nice down at the dam and Ken, the windy roads :D
Aaaahhh shit , that tends to take the gloss off the day.
Hope everyone is alright and they all have insurance.
Poor sneeza , first country cruise with the lines and that happens.
Cheers
Ken
Nope , checked that.
The fairy is not on , or the cruise Nasty ( err Nazi ) and Skyzerr's gone to jam pearls with Kyles ( or is that pearl jam ?? ).
And Niz , the poor baby:D is in bed.
Bloody weak young kids these days:rolleyes:
wheres ya stamina ??
Cheers
Ken
Originally posted by 33Spec2
wats the best way 2 post pics?
do i hav 2 post em one by one?
One by one and must be under 102,400 bytes.
I usually convert mine as though I'm going to email , then drag and drop.
I am sure our resident computer nerds have a MUCH better way but it works for me.
Cheers
Ken
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
