  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Only person I know with aftermarket ecu is EVLR33 - he bought Kens PowerFC before I could get some money together.
Can get a new PowerFC + HC from Nengun for $1700 delivered. If I knew that would solve the problem I would order one tomorrow & prepare to be castrated:)
Yep - that's the problem though cos you can't expect them to spend their time testing things without getting paid.
Might ask Brett about his PowerFC. Might also order a new harness cos I can get one for $600, just have to wait a few weeks for it to be made & sent from Japan.
I don't mind one that's not new, but I believe there is a bit of work installing them so it would make sense to put one in to stay, therefore better not to risk one that may also have problems.
Then again, depends on how much I can get a second hand one for - I already borrowed one off Ray last year just to check against the mess that the japanese owner had left - used to be able to stall the car by jiggling (hmmm...images non car related come to mind!) the harness near the ecu.
Yea , Yea , I'm here . Geez you whores make hard to catch up.
Phptf , stop trying to hit in Lauren , we were all here first.
Micko , I'm still thinking about the problem but I'm leaning towards AFM 's or wiring still .Don't think a new harness will cover that bit.
Cheers
Ken
Hey Ken - hope I didn't get you in too much strife today! Seemed like you relished the chance to take a break from your household duties anyways:)
Car was idling at 1100rpm on the way home with a/c on. Switched it off & revs went to 1300??? Started later & idling was at about 600??? What the?
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
