  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kym,
It's not better, there is no real conversations, just idle banter.
Bully, You must be embarrassed by Psiker:p
See'ya:burnout:
No im very proud off both my sons they are wonderful -- im sure Psiker would buy a quality vehicle if he could but his situation at the moment precludes that -- i have been there and done that and understand that you cant have everything u want at once
bet your happy to get it back - becareful when you get it back - last time i got my car back from a long 3 week stint away i took it for a bit of a drive (hmm if you could call it that) got a little too excited going around a corner and spun it out - luckily noone was coming the other way and i didnt hit anything or anyone.
Hows the shirts going?
Originally posted by skyzerr33
will re open when forum rules are adhered to
other wise u have the mirc channel
Troy
What is this all about ??
I thought this was whoretown and was used for general chit chat and as Niz pointed out * to get to know people*.
The threads I believe have cleaned up and the W A ones certainly appear to stay on topic.
There appears to be a few members who believe that is not so and I don't know what they are referring to.
If it's this thread then simple , don't open it , stick to the sections that interest them .
Cheers
I'm confused but whats new
Ken
PS mirc is usually more mindless one line drivel than here and favours the fleet of fingers
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
