  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kym,
It's not better, there is no real conversations, just idle banter.
Bully, You must be embarrassed by Psiker:p
See'ya:burnout:
No im very proud off both my sons they are wonderful -- im sure Psiker would buy a quality vehicle if he could but his situation at the moment precludes that -- i have been there and done that and understand that you cant have everything u want at once
bet your happy to get it back - becareful when you get it back - last time i got my car back from a long 3 week stint away i took it for a bit of a drive (hmm if you could call it that) got a little too excited going around a corner and spun it out - luckily noone was coming the other way and i didnt hit anything or anyone.
Hows the shirts going?
Originally posted by skyzerr33
will re open when forum rules are adhered to
other wise u have the mirc channel
Troy
What is this all about ??
I thought this was whoretown and was used for general chit chat and as Niz pointed out * to get to know people*.
The threads I believe have cleaned up and the W A ones certainly appear to stay on topic.
There appears to be a few members who believe that is not so and I don't know what they are referring to.
If it's this thread then simple , don't open it , stick to the sections that interest them .
Cheers
I'm confused but whats new
Ken
PS mirc is usually more mindless one line drivel than here and favours the fleet of fingers
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
